Introduction: Easy Plate Cleaner Bot
This bot can be made from simple household items and is easy to use and make
Step 1: Materials
Materials:
-A Rumble Motor (Can be found in a PlayStation or Xbox Controller)
-A 9 volt battery
-Any small scrub brush
-2 wires
-A soldering iron, solder
-Basic soldering skills
Step 2: Soldering
Solder the wires to the two little nubs on the bottom of the rumble motor
Step 3:
Attach the battery to the scrub brush,, i used tape for ease of replacement, glue works as well
Step 4:
Attach the rumble motor to the brush/battery, attach on of the wires to either terminal ( positive/negative don't matter)
Step 5:
Create a means of attaching the other wire to the other terminal
Step 6:
Attach wire and watch her fly.
Step 7:
Supercharged Contest
Holiday Contest
5 Comments
9 years ago on Introduction
Its a gd idea, bt it will be better if you post a video
Don't run this on plates soaked in water. It shorts it out and when you pick it up wondering whats wrong it gives you a little jolt.
post a video of how it works please .
9 years ago
^^^ditto.
can ye post a vid plz?
