Easy Smurf Costume With Pattern
174,013
58
25
Introduction: Easy Smurf Costume With Pattern
About: Check out my etsy shop too! etsy.com/shop/scoochmaroo
It will take you longer to paint yourself blue than it will to make this easy Smurf costume! In ten minutes or less, you can make this super simple Smurf hat (known historically as a Phrygian cap) from the pattern included. All you need is some white fleece (or red if you're dressing as Papa Smurf!) and basic sewing skills (ok, I won't tell if you use staples instead), and you're ready to go!
Step 1: Materials
I used 1/2 yard of white polar fleece for this hat. I ended up stuffing the tip of it with polyester fiber fill. Traditionally, these types of hats were often used to store and carry supplies. Sort of like head pockets! What do you think Smurfs kept in there?
Download and print out the attached pdf pattern, gather your scissors and thread (ok, I used a sewing machine for this), and let's get started.
Step 2: Cut
Tape together the two pattern pieces, and compare the bottom measurement with your head measurement. You may want to adjust the pattern to be larger or smaller to suit your needs. I made the pattern extra long so I could fold the excess to the inside. You can decide how long you want the hat as well!
Trace the adjusted pattern onto your fabric.
Add 1/2" seam allowance all the way around and cut out. You'll want to cut out two pieces.
Sew the pieces together along the curved edge, leaving open along the bottom.
Turn the hat right-side out.
Step 3: Finish
I stuffed some polyester fiber fill into the end of the hat to make it look more cartoony.
Next I tried the hat on and figured out where it bent naturally on my head. I pinned the tip to the body of the hat and sewed it down so it wouldn't be so floppy.
That's it! Add your blue body suit (or, if you're very brave, paint), white pants or dress, and you're ready to go Smurfing around town!
Halloween Easy Costumes Challenge
Be the First to Share
    • Home Decor Challenge
    • Toys & Games Contest
    • Box Challenge
      Box Challenge
    25 Comments
    zak.darwood.9
    This is brilliant! Going to be making this tonight for my halloween outfit.. Zombie Smurf.. :)
    C-Dog107
    C-Dog107
    7 years ago on Introduction
    If I am using fleece material I only need to use part A. To enlarge part A do I just blow it up on a copier? Thanks
    C-Dog107
    C-Dog107
    Very Cute hat smurf hat! Do I enlarge the pattern on a copier and also what is pattern B for the base of the hat I am supposed to use two of pattern A right ? thanks
    mdeblasi1
    mdeblasi1
    I wanted to learn to make a Phrygian cap,
    this looks good to me!
    Jayefuu
    Jayefuu
    Since you apparently have so much blue paint, you should do Mystique from Xmen this year Sarah :D
    askjerry
    askjerry
    9 years ago on Introduction
    1) Excellent costume, and the Instructable was well done too.
    2) She's a Smurfin' hottie. :-)
    ...couldn't resist. (grin)
    OT4
    OT4
    He was just joking
    circuitmage
    circuitmage
    I don't remember Easy Smurfette....OH...the costume is easy...I get it now. j/k
    Smurfy.
    flsmw
    flsmw
    This looks great, although I have one question:
    It looks like you used 2 pieces of piece A. Where does piece B figure into these steps? On your pattern, piece B does not have a coned top.
    Also, did you finish the bottom edge?--Thanks
    scoochmaroo
    scoochmaroo
    Part B gets taped onto the bottom of Part A, with the two hash marks aligned. I did not finish the bottom edge because I was using fleece. If you use a woven material, you will need to finish the bottom edge, or it will fray. Great questions!
    flsmw
    flsmw
    Oh, thanks. I guess that makes sense now that you pointed it out.
    The pattern was split into 2 sections because it's larger than a piece of paper. Thank you so much.
    I am making this for a friend and if the rest of her costume comes together, I will try to post a picture.
    lalunette
    lalunette
    As a child I read all of the original French "Schtroumpf" kid books and I laugh every time I see the English adaptation of the name... it sounds so... squishy !!
    Regardless of that, nice costume... and I love the blue skin !!!
