Easy Ways to Make a Simple Greenhouse
Intro: Easy Ways to Make a Simple Greenhouse
Spring is right around the corner, which means the time to start planning your garden and starting your seeds is now. The first day of Spring is officially March 20, but every good gardener knows that essential garden prep begins long before that. The only problem? The weather doesn't exactly cooperate with the calendar.
Late season frosts and snow are a familiar foe to many gardeners around the country and can bring garden prep to a complete stand still Many gardeners have to deal with moving plants inside and pressing pause on preparations for the coming season. At worst, precious seedlings can be lost and you may find yourself having to start over completely. Fortunately for those of us in colder climates, there is a way to start your garden without having to worry about the weather, and that is by create a Victorian Greenhouse.
Benefits Greenhouses allow you to start seeds by protecting your plants from frost, snow and cold temperatures. While you might think of the typical greenhouse as a bulky structure that only growers use, there are plenty of smaller greenhouse options for your hobby gardeners — including more than one DIY option. These greenhouses are inexpensive, easy to assemble, and come in a variety of different sizes depending on the needs and desires of your individual hobby gardener. For information please visit - https://planetgreenhouse.com/collections/premium-glass-greenhouses
STEP 1: Determine the Design and Size
The first step in making a greenhouse or green house is to determine the size, in addition to preparing the land according to the area you previously determined.
Determining the size, design and direction of the building is also important in building a greenhouse for the functionality and effectiveness of the entire operation of the greenhouse.
STEP 2: Designing the Greenhouse Framework
After determining the design and size, you can start building the framework structure. If you are making a tunnel type, then arrange it from the walls, doors to the roof and then connect one by one the measured PVC pipes until the structure is strong and use glue or rope to further glue the parts together.
On the other hand, if you want to make a greenhouse that is more durable then you can use harder materials such as wood or iron for use with these materials which will be strong in any conditions and weather.
However, all of that is optional and depends on your choice, this is because making greenhouses should be made of thin and light but strong materials.
STEP 3: Close Out Framework
So, if you have finished making the framework, the next step is to cover it on the roof, don't forget to prepare the ultraviolet plastic that you have purchased with a size that is adjusted to the roof of the green house. One type of plastic that you can use is polycarbonate, you need to remember to choose a type of plastic that at least doesn't tear easily. If so, cover the wall with paranet.
You can use nails, bolts, glue or rope to lock it so that it is more adhesive according to the material used then attach all the framework so that it is not easily blown away by the wind especially since the material is plastic.
STEP 4: Finishing
After everything has been awakened, then all you have to do is do the finishing process. This should be done from the outside and the inside.
For the outside, you can make sections to make it easier to water the plants. While on the inside, you can make shelves that are partitioned or make a kind of pot as a place for plants and you also need to make ventilation on some walls that are easy to fold. Then, create additional lighting sources for conditions so that the plants are healthier and stronger.
