Easy Bow Creation
Intro: Easy Bow Creation
!DISCLAIMER! I am not held responsible for any injuries caused by this tool. Although this is not as powerful as a real bow, it can still cause blunt force injuries. Please check what your local laws state about this object. Please remember this is a TOOL not a TOY.
I give permission to modify this in anyway you decide.
Ok so there are only a few items you need, Black reticulation pipe (pvc pipe will not work), rope and a small stick or something that will fit in the pipe.
STEP 1:
Insert the rope into the pipe all the way so it makes a loop and tie the rope together.
You can use the knot as an arrow guide or stick it in an end of the pipe.
STEP 2:
Put the stick horizontal compared to the rope and twist until the rope becomes as tight as you like.
STEP 3:
Put the stick into the pipe and hammer it in as far as it will go. The rope should be really tight
STEP 4:
You are ready to use now! I recommend using a bamboo stick with a honkey nut (if you are Australian) on the front and feathers taped or stuck in the end on the back in a delta (triangle) formation.
2 Comments
lemonie 13 years ago
Needs photographs.
L
Kiteman 13 years ago
