Introduction: Easy to Fold Ninja Star
This tutorial will help you make a ninja star. Can be done by even beginners!
Supplies -
Two Pieces of Paper
Scissors (Optional)
Glue (Optional)
Step 1: Fold Rectangle Into Square
Take the Rectangular piece of Paper (if it is) and fold it so that the right (or left) reaches the left(or right) edge. If it is already a square, you can skip this step.
Step 2: Tear the Square
Take the rectangle with a fold and tear the folded square out ( or cut it with scissors)
Step 3: Fold the Square in Half
As the step says, fold the square in half like so
Step 4: Fold the Edges of the Square Inwards
Open the square and fold each edge to reach the halfway point for both sides
Step 5: Fold the Square in Half (again)
Fold the rectangle that you get in half
Step 6: Repeat All the Steps So Far With the Other Piece of Paper
Take the other piece of paper and repeat the same steps to get two identical pieces of papers - like so
Step 7: Fold Both Papers in Half
Fold both papers in half to get a halfway point whose use will be in the next step
Step 8: Take the Top Left Corner and Fold It So That the Left Edge Reaches the Half Way Point
This is where it starts to get tough.... Take the paper and use the halfway point you got as a reference to where the left edge goes
Step 9: Fold the Other End the Opposite Way
Repeat the same step with the other end, but make sure that both ends face opposite ways
Step 10: Repeat the Same Step With the Other Paper, But the Opposite Way
Take the other piece of rectangular paper and fold it so that the top faces the same way as the others bottom and the bottom should end up facing the same way as the others top. It should something like this, one like a 'S' shape, and the other like a 'Z' shape.
Step 11: Flip the Paper and Fold the Excess
After you flip the paper, you will see two squares. Fold the squares diagonally in half in such a way that it's edge faces the opposite way the parallelogram (shape between the excess) faces
Step 12: Repeat the Same Step With the Other Peice
Repeat the same step with the other piece of paper
Step 13: Fold the Triangles Inwards (both)
Fold the triangles that you get inwards in such a way that it covers the parallelogram
Step 14: Flip the Paper (for Only One) and Place One on Top of the Other
Place the 'S' over the 'Z' but make sure that you only flip the 'S' backwards. It should look something like this.
Step 15: The Hardest Step... Put the Triangles Inside the Folds
On both ways, you should see that there are two big triangles open on their base. Over here, put the triangles inside the folds in such a way that they don't collide with each other, but are instead touching each other's edges. Once you put all 4 of them in, it should look as follows ---
Step 16: The Final TRIANGLE!!
Once you completed the previous step, all the folds should be in and it should look something like this, a Ninja star with four sections if you look either way.
Paper Contest
