Introduction: Easy to Make (and Safer to Breathe) Napalm
Materials that you will need:
Empty jar (I used a pickle jar, I also already have a little bit left from my last batch)
Stick (spoon, straw, etc.)
Citronella oil (Lighter's fluid will also work)
Powdered Sugar
Warning: This stuff will continue to burn as it falls apart. Fire burns. Ouch!
Just to answer everyones' questions/comments: This isn't Military grade napalm, nor does it use a Styrofoam and gasoline mixture (known famously as a "Homemade Napalm"). Also the oil is "Lemon scented" in this version, which usually means someone, somewhere was smelling the fumes let off by burning it, which means that you probably (I can't guarantee it cause you may be allergic to something in the oil) won't die from it.
Here's a Wiki excerpt explaining REAL NAPALM:
"Napalm is usually a mixture of gasoline with suitable thickening agents. The earliest thickeners were soaps, aluminum, and magnesium palmitates and stearates. Depending on the amount of added thickener, the resulting viscosity may range between syrupy liquid and thick rubbery gel. The content of long hydrocarbon chains makes the material highly hydrophobic (resistant to wetting with water), making it more difficult to extinguish. Thickened fuel also rebounds better from surfaces, making it more useful for operations in urban terrain.
There are two types of napalm: oil-based with aluminum soap thickener, and oil-based with polymeric thickener ("napalm-B").
The United States military uses three kinds of thickeners: M1, M2, and M4.
- The M1 Thickener (Mil-t-589a), chemically a mixture of 25% wt. aluminum naphthenate, 25% aluminum oleate, and 50% aluminum laurate, (or, according to other sources, aluminum stearate soap) is a highly hygroscopic coarse tan-colored powder. As the water content impairs the quality of napalm, thickener from partially used open containers should not be used later. It is not maintained in the US Army inventory any more as it was replaced with M4.
- The M2 Thickener (Mil-t-0903025b) is a whitish powder similar to M1, with added devolatilized silica and anticaking agent.
- The M4 flame fuel thickening compound (Mil-t-50009a), hydroxyl aluminum bis(2-ethylhexanoate) with anti-caking agent, is a fine white powder. It is less hygroscopic than M1 and opened containers can be resealed and used within one day. About half the amount of M4 is needed for the same effect as of M1.
Starting in the early 1990s, various websites including The Anarchist Cookbook advertised recipes for homemade napalm. These recipes were predominantly equal parts gasoline and styrofoam. This mixture closely resembles that of napalm-B, but lacks a percentage of benzene.
Napalm reaches burning temperatures of approximately 1,200 ðC (2,200 ðF). Other additives can be added, eg. powdered aluminum or magnesium, or white phosphorus.
In the early 1950s, Norway developed its own napalm, based on fatty acids in whale oil. The reason for this development was that the American-produced thickening agent performed rather poorly in the cold Norwegian climate. The product was known as Northick 11II.
Some weapons utilize a pyrophoric variant, known as TPA (thickened pyrophoric agent). Chemically it is a triethylaluminium thickened with polyisobutylene."
Step 1: Mix Them Together and What Do You Get...
Video Below...
1. Take the powdered sugar and pour about a cup into the jar.
2. Now take the oil and pour about a 3/4 cup into the jar.
3. Mix them together, add more oil or sugar as needed until you get a mixture that resembles whipped cream or butter.
That's all there is to it. Easy as I said it would be. There's a Video below so you can watch how well this stuff burns (a nice steady pace). This stuff does become kind of hard after being stored for a while. Just take the spoon and mix it up, good as new.
Experiment with it to get new effects.
Add regular or brown sugar into the mix.
Try mixing some saw dust in.
Hope you've enjoyed this instructable. Next time you're at a BBQ, take a jar of this stuff out and smear it on the grill (on the coal, not the actual grill) to help start the fire.
181 Comments
12 years ago on Introduction
okay i took gasoline and i put styrofoam in it and it did absolutely nothing whadda eff is up?
Reply 4 years ago
your comment is nine years old but to anyone else with the same problem try making a double boiler and leaving the gasoline in the inner tub or bowl or pot and slowly adding in shredded crumbled or torn up Styrofoam i also recommend taking a soap bar to a cheese grater and adding that to your mixture if its looking thin
Reply 12 years ago on Introduction
It has to do with what type of Styrofoam is used, I find that the white Styrofoam that is used to cushion large appliances and furniture works great but, the outer most part of the foam seems to be a coating or maybe just more compacted (probably the later) and does not dissolve as well. Another source of failure could possibly be caused by different additives to gasoline in different areas. The amount of benzene that is added to gasoline has steeply declined as it known to be very bad for you like most organic solvents and is more likely to be what dissolves the Styrofoam in the first place. I like to use a 2 stroke engine mixture for making napalm. If you are unaware, 2 strokes run off of a fuel/oil where you add oil to the gasoline to obtain a ration of gasoline to oil of around 20:1 or more. Sorry for such a long comment but i hope that it is an adequate explanation for your pyrotechnic/pyromanical dilemma . Feel free to message me if you have any questions.
loopycar27
It's been five years since you posted this, but I'm not finding much help in determining the styrofoam to gasoline ratio to create a fuel that will be acceptable in an internal combustion engine. Do you have any experience with that?
Reply 6 years ago on Introduction
1 part foam for 1 part gas. So.. if 35 grams of gas (50ml), then 35grams of foam.
Reply 6 years ago
if you leave the Napalm in a container filled with gas for more than a week it turns into a translosent putty
Reply 11 years ago on Introduction
i use pink extruded styrofoam... i have like messed up sheets of it
Any ideas on the various styrofoams- like packing peanuts- if it burns like sterno small quantities might be useful.
L8r
Mike
u hav to heat the gas, VERY CAREFULLY, then u cut up a bar of soap into smal shavings and then break up the styfofoam and mix them together.
Ummmm i'm sorry but wouldent it help if you actually LIGHT the napalm with fire?
4 years ago
Well I’m on a list now
6 years ago
Styrofoam and 32:1 two-stroke gas works best. You can obtain various thicknesses by adding more or less Styrofoam and by letting it "cure" for several days and it works well as an improvised drip torch for setting backfires in the wild land fire fighting setting. I've used it on wet brush piles to good effect. It's nothing you want to be near while it's burning. The fumes are toxic and a thick sooty smoke it produced. The pros are that it's very sticky even while burning. At high ratios of foam to gas It can be twisted into a stick to form a drip torch or it can be dispersed manual by pouring from bucket. A remarkable amount of Styrofoam can be dissolved in a small volume of gas. It's been decades but I want to estimate about 5 pounds of Styrofoam per half coffee can of gas to make a super thick gel.
6 years ago
this stuff sticks to skin partially because thickening agents are pretty strong.
6 years ago
we made it in SF. gasoline, fab laundry detergent, burnt motor oil and Styrofoam. Styrofoam is just styrene with a blowing agent added to convert it to foam... in this mixture it helps it to be sticky and being foam helps it melt in quicker. the soap is the thickener and the oil prolongs the burn time. you can vary the percentages for different needs. the military m2 thickener worked great but we could get detailed results making out own... gas and styro first. then oil...last in is the fab...for some reason fab worked best
6 years ago
hey a quick question for the homemade napalm, can you use any type of styrofoam?
13 years ago on Step 1
can you do anything evil and/or cool with the waxy stuff it leaves behind???
Reply 13 years ago on Step 1
by waxy stuff do u mean the napalm itself? ya u light it on fire and watch is burn. btu be carful u cant put it out with water
Reply 13 years ago on Introduction
my friend said that if you mix cooking oil and flour it will have the same effect. Is this true, too much snow to test here
well in the most basic way you can make an explosion out of flour but to get it to work you need so much room to do it, its just not worth it.
also oils can be used to make an explosion. with great force
the most basic example of these is the original diesel engine.
it ran on peanut oil!
uhh..i dont think itd work
