Introduction: Edible Nutella Slime / Play Doh
In this Instructable, I'll show you how to make edible slime / play doh using Nutella!
Here's what you'll need:
- Nutella (1 tablespoon)
- Corn Starch / Corn Flour (1 tablespoon or more)
- Condensed milk (200ml or 7oz)
Other items you'll need :
- Mixing utensil, such as a spoon.
- A stove
- A small pot or pan
Step 1:
The easiest way to follow along with this instructable is to watch the video above or on my channel by clicking this link - http://bit.ly/1ODLIwG
If you're a fan of reading lengthy articles, go to the next step.
Step 2: Pre-heat Pan at Low Heat
The first step is to switch on your stove and pre-heat a pan or pot at a low heat. You don't want to set it too high as excessive heat will burn the condensed milk.
Step 3: Add Condensed Milk
Once your pan has warmed up, pour in your condensed milk. Remember, we'll only be using 200ml/7oz of this delicious stuff so be sure to not exceed this amount.
Step 4: Add Nutella
Next, add 1 tablespoon of Nutella. Adding too much Nutella might cause the mix to caramelize a bit so be sure to stick to the recipe.
Step 5: Add Corn Starch / Corn Flour
Depending on where you are from, you'd know this ingredient by different names.
Add 1 tablespoon of corn starch / corn flour and mix the ingredients together until combined.
Step 6: Keep Mixing
Once combined, remove off heat and cool down at room temperature.
If your mix does not thicken after 10 minutes, simply add more corn starch / corn flour until you are happy with the texture. The mix does tend to get sticky after a while so adding more corn starch / corn flour may be necessary.
Step 7: The Result!
After about 10 minutes of cooling down and adding few more table spoons of corn starch, I ended up with a slimy play doh - like result.
It did taste yummy but, not exactly like Nutella. I'd say it tasted a lot like nutty cookie dough.
If you liked this Instructable, check out some of my others and hit the follow button to be notified when I post something new.
Watch the video to see me play with the slime!
