Educational Board for Attiny 2313
Intro: Educational Board for Attiny 2313
I've made this board for learning uC programming. It's very simple and easy to solder. As programmer I'am using USB_ASP - project from site www.fischl.de/usbasp , but there could be used any other porgrammer for avr's with ISP connector. Project was realised in EAGLE. I'm attaching schematic and board files.
STEP 1: Making PCB
PCB was done by the termo-transfer methode ('cos it's best methode i've ever tried).
Here is list of all parts:
Capacitors: 1x 100nF; 2x 33pF
Resistors: 5x 260Ohm , 1x 4.7kOhm
IC: Attiny2313
Others: 5 led diodes, connectors as on images
IC: Attiny2313
STEP 2: Ending Result
At the end, the photo of this board, just assembled and working.
6 Comments
jue2010 4 years ago
jue2010 4 years ago
Eonir 14 years ago
jopiek 15 years ago
board_2.0_alphaboard_2.0_alpha
circuit_2.0_alpha
I added a jumper fot the resistor as it seems to be that (at least for me) programmers like the STK500 and the Dragon don't like the resistor for programming. So the jumper J4 should be unplugged when entering programming mode. Also, I made a minor change so don't need a bridge wire around the same area (the resistor of the single LED).
andrew101 16 years ago
kubeqz 16 years ago
