Egg Crush Physics
Intro: Egg Crush Physics
Let's keep it simple!
In this project, students must build a contraption that can protect an egg from being crushed. The only materials they are allowed to work with are flat wooden toothpicks and wood glue. The force being applied to the egg contraption is in the form of a 5 gallon bucket falling from above. If you're a teacher friend, continue reading below. If not... don't bother with the reasons for the experiment and skip to the fun part.
You can check out the videos on step 4 for a better idea of what happens to the final product!
Objectives: Student will demonstrate ability to...
1. plan and build a device to protect an egg from forces acting on it.
2. identify the forces acting on their egg contraption and build accordingly.
3. compare and contrast what worked vs. what didn't work.
4. reflect upon what they would do differently.
5. collaborate in small groups throughout the process.
6. calculate the forces acting on their egg (momentum, force, acceleration, speed, velocity)
7. identify where Newton's 3 laws of motion can be observed in the schematic of the experiment.
This lesson can be easily differentiated. (less toothpicks, less time to build, increased mass in the bucket, higher drop height... you get it)
Students can work in pairs or go at it alone. I do not recommend bigger groupings.
STEP 1: Materials
The materials for this project are cheap and easy to acquire.
For the build you will need...
a. 200 flat wooden toothpicks. (I found the mass of 200 toothpicks is 11.3 grams. I measured out 11.5 because some toothpicks are bound to be bent / broken / too skinny... You can have the kids count them out after you hand them out if they think you shorted them. This way you don't have to take time to exchange bad toothpicks)
b. Wood glue
c. Wax paper
d. Graph paper
e. 3.5 oz bathroom cups (I like plastic better because they hold up for multiple uses)
Optional
plastic Easter egg, ruler, scissors
For the test you will need...
a. 5 gallon bucket (1)
b. Eggs (One for each project built)
c. A pulley (optional... just helps decrease friction)
d. Rope (length depends on how high your ceiling is)
e. mass to add to the bucket (I used textbooks)
f. a meter stick or yard stick to measure how high the bucket is when you drop it.
b. Wood glue
c. Wax paper
d. Graph paper
Optional
STEP 2: The Pre-build
Here are the first three things I tell my students.
1. Imagine where the force is coming from. Where will you need the most support? Hint: A roof will NOT help protect your egg.
2. This is a three dimensional project. (You need to plan out the walls, build the walls laying flat on the table, let the walls dry, and then stand the walls up and glue them together. Make sure you check out the picture that shows what NOT to do.)
3. Don't waste your time and wait for toothpicks to dry. There is always something you can work on.
I start class with a warm up (do now) on one of Newton's Laws and how it relates to the project. After reviewing student generated responses, they can get their project and start / continue building. They will need a refill on glue at the start of class each day.
STEP 3: The Build
When building it is important to do the following...
Work on top of the wax paper.
Glue toothpicks together.
Let toothpicks dry.
Protect egg at all costs!
Below are some ideas my students came up with.
Let toothpicks dry.
STEP 4: Testing Time!
This is how I do it. You are free to modify.
1. Place the egg contraption beneath a 5 gallon bucket with a predetermined mass (I use 2 textbooks in the bucket).
2, Add some construction paper beneath the contraption to make clean-up easier.
3. Gently place the bucket on top of the contraption.
4. Raise the bucket six inches and drop it on the contraption.
5. If the egg is still in tact, raise the bucket 12 inches and drop it on the contraption.
6. If the egg is still unscrambled, raise the bucket 18 inches and drop again.
7. I usually stop at 18 inches. If the egg survives from this distance, the project in my mind is a success.
20 Comments
2026riquinn 2 years ago
greghunter901 9 years ago
OMGEEEE IM BUILDING THIS LIKE RN DRING SYENCE CLASS TOTES COOLIO :)
Biodynamic 9 years ago
TheFlorifant 10 years ago
I do not get why you make cubes, wouldn't piramides or "pillars"(=cilinders with wider top and botom than the middle) work better. I think they would as they channel the energy and force to the table skipping the egg. Could you explain this?
owlsquest 10 years ago
I alternate with my Physics 20 class; building one egg drop/crush using toothpicks first semester, then in second semester the next class uses Fettuccine pasta for the build. Ground rules for Fettuccine pasta give specific lengths that are allowed for the build. I don't usually need to 'police' that rule as students being so competitive make sure no group breaks the length rules.
Biodynamic 10 years ago
Students are given a 'kit' containing pasta(300g), hot glue(15 sticks) and mini hot glue guns. Bridge building or stress vs. load concepts are discussed in the first half of period then they brainstorm for second half. At the end of that block they must present a finished diagram with measurements for approval. Next block (blocks are uniform at 90 min each) they build. Students are given an additional five periods to tweak their projects--the last 20 minutes of class. They may also do so after school or at lunch. If they require more supplies, they may trade amongst themselves but nothing comes in from the outside, this is well policed by students. All bridges are tested by adding weights hung from the centre of the bridge which itself is suspended between a stack of textbook, usually 20 cm off the bench surface. Weights are available throughout the project for testing. Egg drop is tested from the second floor into the rotunda area at the front of our school. As a courtesy to Facility, each competitor is given a green garbage bag to house the egg contraption.
Hadn't thought about making an 'ible. Short photos as our Board has massive paperwork if we want to photo students but I may have some with only the projects in them.
antibobthebuilder 10 years ago
sokamiwohali 12 years ago
mrmerino 12 years ago
It makes me angry every time I think of it.
ladieslilman98 12 years ago
macrumpton 12 years ago
Jayefuu 12 years ago
sherrycayheyhey 12 years ago
We had to make something to drop the egg into from the stairs. It was set up like a contest, the height the egg was dropped from was divided by the height of the egg drop container.
I made mine from a very shallow cardboard container filled with sand and I won! My egg only cracked because it was dropped and didn't land in the box.
Some other kid dropped his in a bowl of honey of honey but his container was much taller than mine. We were supposed to drop from incrementally higher steps but he skipped them all and went to the top and got lucky. The teacher gave us both extra credit but I still say mine was more legit :|
lemonie 12 years ago
L
rickharris 12 years ago
Biodynamic 12 years ago
allesflex 12 years ago
