Electric Altoids Guitar/Ukulele
Intro: Electric Altoids Guitar/Ukulele
STEP 1: Materials & Tools
Materials-
- Altoids Tin
- Wooden Slats/Stick (width should be about 2 inches)
- Guitar tuning pegs (4)
- Piezo buzzer
- 1/4” audio jack
- Gorilla glue
- Electric Guitar Strings
- Bic Pen
- Tape
- Solder Wire
Tools I used-
- Drill Press
- Band saw
- Pneumatic rotary rasp bit
- Scissors
STEP 2: Attaching the Neck
Measure how far you want the neck to sit in the tin, and the amount of space you want on the ends of the wood for your guitar pegs. Then using a band saw, cut half way through the thickness of the wood.
Cut a slot in the side of the Altoids can that you want the neck to be on. (keep in mind the orientation of the logo on the tin.) Make sure it's the same size as the wood so it fits.
To do this, I drilled a hole and used the rotary rasp bit to carve away the tin. If you don't have this, you can also use a router bit on a dremel tool instead.Once the slot is cut, place the wood inside, and use glue to secure it. This is the basic body of the guitar.
STEP 3: The Details
- Using the Drill press, drill a hole on the side of the tin to mount the mono jack.
- Measure and drill holes for the tuning pegs (stagger them so the strings don't get too close to each other.) Secure them onto the headstock.
- Drill holes in the tin for strings, and a very small hole on the center of the cover for the piezo sensor (I used a hammer and chisel to make the holes.)
- Cut a Bic pen cap in half to use as the bridge. Glue it on the edge of the tin.
Using the Drill press, drill a hole on the side for the audio jack, and mount it.
STEP 4: Electricals
Wire the piezo sensor to the audio jack. Be sure to test it before securing it permanently.
Finally, run the strings through the holes in the tin and run them to their tuning pegs.
Hook it up to an amp and start jamming!
10 Comments
404_Error 13 years ago
saramaier825 13 years ago
FinchbyFinch 12 years ago
Sabazius 13 years ago
However, a piezoelectric pickup works by translating the vibrations of the sound into electrical signals, which a connected amp converts back again and amplifies/distorts/whatever. As such, if it makes a noise, the piezo will register that noise. Although a nylon string will probably make less noise than a metal string, purely because of the nature of the material, there's no scientific reason I can see to prevent you using a piezo with nylon strings.
FYI, piezos are used on all kinds of acoustic instruments with non-metal strings, such as instruments in the string family which are played with a bow. Hope this is informative and helpful :)
ScienceWiz 14 years ago
I'm really lookin to make one, and, if I finally do, Ill upload a video of me playing it so people can hear how it sounds.
Great instruatable! Great idea
lemonie 14 years ago
L
saramaier825 14 years ago
L
masterochicken 14 years ago
Badger_Man 14 years ago
