Electronic Dice!!!
Intro: Electronic Dice!!!
ABOUT THIS PROJECT
I made a dice throwing prototype: if you press the button, a random number between 1 and 6 is generated and the corresponding number of LEDs are lit up. This was a holiday project with my kids :)
Dice throwing prototype using Arduino UNO, a button switch and 6 LEDs.
Full tutorial on my channel visit my channel for full tutorial!!!STEP 1: Parts & Materials Required!!!
- Arduino uno
- 6x LED'S
- A breadbord or a prototyping board
- 6x 220 ohm Resistors
- 1x 1k ohm Resistors
- A push button
STEP 2: Circuit Diagram!!!
I have made a circuit diagram for the connections of Arduino,led,push button and resistors.
see the circuit diagram for the connections.STEP 3: Connections!!!
Now connect led's negative terminal to the 220ohm resistors and positive terminal to the arduino's digital pins from 2 to 7.and connect the other led of the resistors to the Gnd(ground) pin.
For rest of the connections for push button see the circuit diagram!!
STEP 4: Additional Changes for the Led's!!!
I have added the BRIDGE like structure at the middle of the breadboard for the led's to rest infront of the wires and resistors JUST TO LOOK CLEAN.
U CAN ALSO SKIP THIS PART IF U DO NOT WANT TO DO THIS.STEP 5: CODE!!
//Now hook up your pc with arduino and just download the below code and upload to your arduino.//Dynamic Innovator// set to 1 if we're debugging #define DEBUG 0 // 6 consecutive digital pins for the LEDs int first = 2; int second = 3; int third = 4; int fourth = 5; int fifth = 6; int sixth = 7; // pin for the button switch int button = 12; // value to check state of button switch int pressed = 0; void setup() { // set all LED pins to OUTPUT for (int i=first; i<=sixth; i++) { pinMode(i, OUTPUT); } // set buttin pin to INPUT pinMode(button, INPUT); // initialize random seed by noise from analog pin 0 (should be unconnected) randomSeed(analogRead(0)); // if we're debugging, connect to serial #ifdef DEBUG Serial.begin(9600); #endif } void buildUpTension() { // light LEDs from left to right and back to build up tension // while waiting for the dice to be thrown // left to right for (int i=first; i<=sixth; i++) { if (i!=first) { digitalWrite(i-1, LOW); } digitalWrite(i, HIGH); delay(100); } // right to left for (int i=sixth; i>=first; i--) { if (i!=sixth) { digitalWrite(i+1, LOW); } digitalWrite(i, HIGH); delay(100); } } void showNumber(int number) { digitalWrite(first, HIGH); if (number >= 2) { digitalWrite(second, HIGH); } if (number >= 3) { digitalWrite(third, HIGH); } if (number >= 4) { digitalWrite(fourth, HIGH); } if (number >= 5) { digitalWrite(fifth, HIGH); } if (number == 6) { digitalWrite(sixth, HIGH); } } int throwDice() { // get a random number in the range [1,6] int randNumber = random(1,7); #ifdef DEBUG Serial.println(randNumber); #endif return randNumber; } void setAllLEDs(int value) { for (int i=first; i<=sixth; i++) { digitalWrite(i, value); } } void loop() { // if button is pressed - throw the dice pressed = digitalRead(button); if (pressed == HIGH) { // remove previous number setAllLEDs(LOW); buildUpTension(); int thrownNumber = throwDice(); showNumber(thrownNumber); } }
