Introduction: Electronic Roulette for Truth or Dare Game
Have you ever been around your friends and being bored as hell?
Well not anymore! I wan't to show you what I created!
The new Electronic Roulette for Truth or Dare Game!
Maybe you're asking why just not use a bottle or something?
Well I thought because I can make a new toy for my friends to enjoy, I made this.
So you just press the button and the arrow will spin until you let go. And the thrilling part, you'll never know where it will stop? That's what makes it exciting!
Step 1: Gather Your Materials
1. An old container - the one I used was from an empty hair wax container
2. A 9v battery
3. 1 100 ohm Resistor
4. 1 Red LED 3v
5. Small DC Motor - the one I used was 6v
6. 1 Normally-open Push switch
Step 2: Make Holes in the Container
One for the Motor
One for the LED
One for the switch
Step 3: Complete the Circuit
I used a battery clip for the battery connections.
I tested the circuit first before finalizing it to make sure it works before I solder the circuit together.
Just refer to my schematic diagram.
Step 4: Soldering the Components Together
BE CAREFUL WHEN USING A SOLDERING ROD AND SOLDERING LEAD
THE ROD CAN GET REALLY HOT AND MAY CAUSE YOU SERIOUS BURNS IF YOU HAPPEN TO TOUCH THE TIP
THE SOLDERING LEAD PRODUCES SMOKE WHEN IT IS HEATED. AS MUCH AS POSSIBLE DO THIS IN AN OPEN AND WELL VENTILATED AREA.
Step 5: Use Hot Glue to Secure the Switch, LED, and the Motor to Your Container
After securing the 3 parts to the case, you can now test you creation!
