Emery Pincushion - Keeps Pins and Needles Sharp - Sew Useful Entry
Intro: Emery Pincushion - Keeps Pins and Needles Sharp - Sew Useful Entry
Are you familiar with the little strawberry that comes along with the famous tomato pincushion? Do you know the purpose of that strawberry? It's an emery pincushion. Its purpose is to sharpen your pins and needles. It is filled with a mineral called "emery". Emery resembles fine metal shavings. It is used as an abrasive in industrial applications and also on many useful household items such as emery boards.
Well, that little strawberry pincushion just wasn't suiting my needs. I needed something larger, something that could sit on its own on my table. I searched high and low for a larger emery pincushion with no luck, so I decided to make my own.
The result? Here it is. This pincushion is small, as far as pincushions go, but large for an emery pincushion.
I'm offering these emery pincushions for sale and entering them into the Sew Useful contest because I feel they are so practical and they're just not available. They serve a great function for anyone that sews. There's just nothing else out there. I saw a need for something, both for myself and for others, and I've fulfilled that need. I saw a gap in what's available in the commercial sewing world, and I believe I've filled that gap with something handmade. What's better?
You can find my etsy listing for the contest at
http://www.etsy.com/view_listing.php?listing_id=5992910
That listing isn't for sale until after the judging on June 18th. If you'd like to purchase a finished pincushion or the loose emery, you can visit my shop at http://dottyral.etsy.com . They're both available there.
You may re-create this pincushion for your own personal use. You may not sell pincushions made using my pattern.
Ok, on to the instructions....
STEP 1: Prepare the Fabric
Here is a list of the materials and tools needed:
muslin fabric, approximately 5"x5"
decorative fabric, approximately 5"x6"
emery
matching thread
sewing needle
sewing machine
scissors
You can make your pincushion any size and shape. The finished pincushion I'll show you today measures 2 3/4" x 1 1/2".
You're going to make the pincushion out of muslin, then cover it with decorative fabric. I do that because I don't want the tiny emery particles to escape through seams and pinholes.
Fold the piece of muslin in half. The fold is now on the left sie. Draw your lines as shown below. The muslin rectangle should measure 1 1/2" x 2 3/4".
Fold the decorative fabric in half, right sides together. The fold is on the left side. Draw your lines as shown below. The decorative fabric rectangle should measure 1 3/4" x 3".
Extend the vertical lines that you drew by about 1/2" inch above the rectangle.
The solid lines are your sewing lines. The dashed lines are where you'll fold it later.
emery
matching thread
sewing needle
sewing machine
scissors
STEP 2: Sew
Now you'll use your sewing machine to sew across the bottom and up the side on each piece of fabric. Be sure to sew all the way up to the top of the vertical line that you drew.
Don't sew on the dotted line.
I used red thread in the picture below. That is for demonstration purposes. You should use matching thread.
After sewing on the solid lines, trim to 1/4" or less along the bottoms and sides. Trim across the top, just above the top of the vertical sewing line.
STEP 3: Turn
Now you turn each piece inside-right. You have two sacks now, each with one closed end and one opened end. The muslin tube is slightly smaller than the decorative one.
STEP 4: Fill
Now you'll fill the muslin sack with emery. I use about 1/8 cup for pincushions this size. Fill it to just below the dashed line inside the sack.
STEP 5: Sew
This is probably the trickiest step.
Use a straight pin to pinch together the top of the sack. Insert the pin as close to the emery as possible. It will help keep the emery in the sack while you're sewing.
Use the sewing machine to sew the sack closed. Go back and forth a couple of times to make sure the sack is closed securely.
Again, I used red thread in this picture so that you can see it. You should use matching thread.
Trim across the top, just above these sewing lines.
It's not very pretty at this point, but "function over form" is what we need for now.
STEP 6: Finish It Up!
Fold the top down on the decorative sack. Fold it to the inside of the sack. You should fold it on the dashed line that you can see on the inside of the sack.
Insert your filled muslin sack.
With needle and matching thread, sew it closed. Use a blind stitch so that your stitches will be virtually invisible.
That's it! You're done!
Now jab all of your pins and needles into that baby. You'll never have dulls pins again!
31 Comments
Nana Sandra 7 years ago
I just purchased emery (powder). How do I ensure that the emery doesn't sift through the fabric I use? I am about to make a few pincushions for friends who sew, but I need to figure out how to keep the emery in place.
Allan Wells 13 years ago
marcolinux 10 years ago
scrub sponge works too. It is not as heavy, but is cheap, easy available and can be cut in many shapes.
dottyral 11 years ago
twinkleshine 11 years ago
firefly68 11 years ago
mybb 15 years ago
And here is dental supply company that has emery in smaller amounts.
I hope this helps
dottyral 15 years ago
ldesimon 15 years ago
UltraMagnus 15 years ago
qwerty90210 16 years ago
ryzellon 16 years ago
I think the photos are pretty self explanatory, though the crudeness might be a bit confusing. (Sorry, I had to improvise on materials.)
If Dottyral, or someone who's pretty adept wants to make this, you're welcome to write up an authoritative account. These steps are really vague and aren't going to be very helpful to someone very new to sewing.
(I hope the images will be accessible in full size...)
Here's what's going on in the photos:
Pouch of tiny metal rings == Pouch of emery
Green lens cloth == Foam block/pouch of packed poly-fill
Blue card == Scrap of stiff plastic (ex-credit card, etc)
Pink/peach tissue == Decorative outer cloth
Vague steps:
- Make a little emery pouch
- Make a foam block about the size of the emery pouch
- Cut a bit of credit card so that it's a little larger than foam/pouch
- Cut decorative cloth so it'll go around your wrist in one dimension, and around the stack of emery/foam/plastic in the other.
- Make sure stack and cloth will fit snugly, sew cloth shut on long side + one short side
- Stuff stack into center of pouch, sew on either side to hold
- Close final side of pouch
- Add velcro
Possible variations:
- Try tapering the long pouch at either end: it'll make the wristlet less cuff-like and give the velcro some reinforcement to hang on to.
- Put a broad swatch of velcro on one side to make the wristlet adjustable
dottyral 16 years ago
woodknot 16 years ago
VanessaEtsy 16 years ago
