Enable Samsung Tv Hidden Menù
Introduction: Enable Samsung Tv Hidden Menù
In this my first instructable I will show how to enable some hidden menù in Samsung tv. To gain access to service menu is enougth to power of your tv and then power on pressing the key sequence INFO MENU MUTE POWER. Unfotunately many options are still hidden and some other special keys need to be pressed FACTORY and 3SPEED not present in common remote !
In order to send these IR codes I make a simple circuit with :
1 - Arduino
1 - Bredboard
1- IR Trasmitting led
1 - 150ohm resistor
3 - button
Some wire
More info about hardware and source code may be found at : https://github.com/ironman977/SamsungIRRemote
After you enter in service menu (INFO MENU MUTE POWER of your remote) press button 2 and ... Tada ! All hidden options are accessible (Control -> Sub Option)
Be the First to Share
    • Anything Goes Contest
    2 Comments
    Ironman977
    Ironman977
    7 years ago
    in the service menu I found how to enable rs232 output :) for more info http://www.samygo.tv
    spongedennis22
    spongedennis22
    7 years ago
    what is good in the service menu that would make you do this
