Entrails (Intestines) Prop
Intro: Entrails (Intestines) Prop
Have you ever wondered how they do the guts in zombie movies when the zombies tear into a victim? Well they use real pig intestines and since that is not an option for the average person decorating their lawn, I decided to show how to make the static version of intestines.
These entrails can be used over and over again even though their not flexible like the real thing.
This project only takes about two days to make and costs about $6 from Home Depot/Lowes and $6 from Michaels.
STEP 1: Materials
These materials can be found at Michaels, Lowes, and around the house-
-Great Stuff Expanding Foam ($3.86)
-Gloss Clear Coat (around 4-5 dollars)
-Cherry Red, Real Red Gloss, and Alizarin Crimson Acrylic Paints. (or any reds ranging from light to dark)
-Paint brushes
-A straw
-Wax Paper
-Cup of Water
-Paper towels
-Newspaper
STEP 2: Making the Guts
Lay a sheet of your wax paper on top of some newspaper as extra protection so that you don't ruin your work surface. Decide the way that you want the entrails to look. Once you have the shape you want figured out, spray the foam onto the wax paper and allow some room because the foam will expand 2 or 3 times its original size.
Let the entrails dry overnight.
Then carefully remove the guts from the wax paper once they dry.
(Note: I was spraying the foam in 113 degree weather and it was not setting. It was almost like soup. So a tip to set the shape you want quickly is to fill a spray bottle with water and mist the water onto the foam.)
STEP 3: Painting and Finishing
This is where your work determines the look of the guts. First thing you need to do is set up your work surface with newspaper, a cup of water, and some paper towels. Next thing to do is get your paint ready for use.
Start by using the Real Red Gloss acrylic paint . Paint the entire piece of foam with this paint. Then switch to Cherry Red acrylic paint and only paint little tiny areas in order to create some contrast to the piece. Sometimes I use this darker paint in the cracks and crevasses to make the guts "pop".
The darkest red (Alizarin Crimson acrylic paint) is for blood splatter. I use the straw in order to create the blood splatter. A better way to have done this is with an airbrush, but I couldn't find where mine was.
In order to create the blood splatter with a straw, you need to use your breath. You suck up a little paint into the straw and then blow it back out until theres very little left in the straw. Then blow the rest of the paint onto the workpiece so that its doesn't glob in only one spot.
The last step is to apply the clear coat and let dry.
6 Comments
lyric66 7 years ago
BTW I also wanted to say I think these entrails are awesome! Thanks so much for taking the time to share these great instructions and for posting them on a free site!
lyric66 7 years ago
Instead of spraying the foam entrails on dry newspaper which is difficult to peel off once the foam dries, I used a large piece of material, a t-shirt or a rag. Hold it under running water and drench it before spreading it out on a flat surface. Then when you spray the foam entrails on the wet material, not only does it help the foam cure/dry faster, but it won't stick so bad and you'll be able to lift it off with little effort.
cillianwall 13 years ago
l8nite 13 years ago
jtmjr 13 years ago
If your use fire engine red high gloss spray paint and then touch up the shadow spots with high gloss black before the red dries it looks great trust me its a lot easier also.
hackmattr 13 years ago
