Epic Pallet Beer Mug
Intro: Epic Pallet Beer Mug
I made a wooden beer mug
Check out my YT channel and
SUBSCRIBE HERE
STEP 1: Preparing
Cutting the pieces with angled edges and cleaning the faces
STEP 2: Cutting the Slots
Cutting the slots for bottom and for rope reinforcement
STEP 3: Bottom of the Mug
Cutting and gluing the bottom of mug and cutting out the circle
STEP 4: Assembly
Gluing the sides and cleaning the joints
STEP 5: Carving
Using the V chisel and gouge
STEP 6: Charring With a Candle
Charring to give carve more depth
STEP 7: Handle and Hoop
Gluing the rope, shaping and instalation of the handle
STEP 8: Waterproofing
Waxing the inside of the mug
STEP 9: Skål (Cheers)
Ready for feasting
16 Comments
pbianchi1 7 years ago
Do you have the measurements of each part? It's kinda complicated to do it without them. Thanks! Great mug by the way.....
Epic Workshop 7 years ago
You divide the 180 degrees with number of pieces you want (12 in my case). which is 180:12=15
That means you would adjust your saw to 15 degrees hope this helps :)
Djhunter84 7 years ago
The traditional way to seal mugs is to put bees wax which I used, but you can also put epoxy (resin) to completley seal the mug.
I think that using bees wax is best way because it gives the beverage... BEER so fantastc honey flavored taste and scent.
Moris
DIY Andrea 7 years ago
It looks and tastes awesome! Great job!
Thank you :)
Tachyon 7 years ago
One concern I have is with using pallet wood for food use.
(everyone's read the pallet safety instructable right? https://www.instructables.com/id/PALLET-SAFETY )
Even with HT pallets you don't know for sure what might have been spilled on the pallets in their former life. chemicals, hydraulic oil from a fork lift, etc.
One possible alternative might be wood scabs from a wood mill. You can often get them free and they're untreated.
Thank you for comment, btw the carving represent Thor`s hammer.
I am aware of pallet use, but this pallet I used was custom made only for bio food products so I am sure that is food safe.
Rexallen 7 years ago
That's pretty darn cool! I want one! Great Job!
Thank you, try to make one :)
sawdust1126 7 years ago
Awesome! Great skill, I would love to try this project.Thanks for sharing it.
You definitely should try to make this project and thanks for your kind words
ClenseYourPallet 7 years ago
Thank you so much more projects coming soon :)
ethanbeasley 7 years ago
Definitely yes, but when the mug has been waxed it is used usually for cold beverages and not for hot beverages.
For hot beverages the mug has metal hoops around and it's been soaked in water for it to expand thus becoming waterproof.
Probably the wax will dissolve anyways but i am not worried because it`s food safe, and the beer has wonderful honey taste to it.
Photo:
The mug on the right is not in use for 30 years and you can see the gap, but if I leave it to soak in water it will expand. The left one is in use every year for vine and has a beautiful taste and smell to it and was my inspiration for my beer mug. :)
Cheers
