Introduction: Equality Cupcakes: Baking and Frosting
Learn how to make multicolored cupcakes and frosting to go along with it!
Step 1: Layer Cupcake Pan With Paper Sleeves.
If you own paper sleeves you can place them in the cupcake pan. If you do not own any you can spray the pan with non stick spray.
Step 2: Preheat Oven to 400°
Step 3: Mix Your Ingredients Into the Mix.
Mix as many or as little boxes of store bought cake mixes with the ingredients it says to on the directions on the back of the box.
Step 4: To Create the Different Colored Batter You Can Either Buy It That Way or Use Food Coloring.
Put enough bowls to compensate for the amount of different colors of batter you want and put as much or as little of the food coloring colors your using into the bowls.
Step 5: Mix the Cake Mix Into the Food Coloring.
You can use a spoon or a measuring cup of 1 cup, and scoop one scoop into each bowl of coloring until your out of non colored batter.
Step 6: Mix Each Color Separately.
Take a spoon or fork or whatever you wish to use and mix each bowl of batter separately until the coloring is fully and evenly distributed throughout the batter.
Step 7: Place Batter Into the Cupcake Pan.
You can use a spoon to scoop a little into each one until the batter has been evenly distributed, you can layer your colored batter over each other if and how you wish to.
Step 8: Bake Your Cupcakes.
Put them in the pre-heated oven and let them bake for 12-17 minutes and if you have extra batter you can repeat these steps until there is no left over batter.
Step 9: Remove Cupcakes From the Baking Pan.
If you used paper sleeves remove the cupcakes from the baking pan and let cool for 10 minutes before frosting or eating. If you did not have papers sleeves to use wait at least 15 minutes to remove them from the hot cupcake pan.
Step 10: Purchase Frosting
You can buy any brand of white frosting to mix with your coloring. If the frosting is not white the coloring wont show.
Step 11: Mix Coloring Into the Frosting.
You redo step 3 for how many colors of frosting you wish to have. Then you just have to scoop as much frosting into the the food coloring as you wish and mix until it is evenly distributed.
Step 12: Decorate Cupcakes How You Wish!
