Introduction: Escritorio - Esquinero
Hello again! Today I present a simple table for your room, which is made to put your computer or even two. It is made to put it in a corner of your room, to save space.
I hope you like it!
-Autodesk Fusion 360
-Patience
-A lot of creative
Step 1:
This desk is made up of 3 top parts. First it will be the part on the left, for that you must create a sketch, then with the "line" tool, assemble each side according to the measurements written in the plans.
Step 2:
In this part we will make the part on the right, which you can create with the measurements written on the plan or simply copy the first step and rotate the result 180 degrees.
Step 3:
In this step, we will make the middle part, which will join the left and right part.
In all the steps we only need the "line" tool and don't forget that with the "extrude" tool the measurement will be 12 cm.
Step 4:
In the fourth step, we will make the table legs, they will be 3 normal because the remaining 2 will need a change. Here are the measurements.
Step 5:
In this step we will make the two remaining table legs, these will have a small opening because the CPU support will be connected there.
Step 6:
In this step, we will make the CPU support, which with the "extrude" tool will be 2mm. Here I put the measurements.
Step 7:
In this step we start with the assembly, first we will attach the normal legs to the left table in respective places. I recommend joining the middle parts of the piece you want to join to where you want to join it.
Step 8:
Finally, we will attach the two table legs to the right hand side and fit the CPU mount into the opening we made in the table legs.
Step 9:
And as the last step to present it, we go to the "design" option, and we choose the "render" option and we choose the type of background or the background color that you like the most.
