Esp8266 Firebase Connection
Intro: Esp8266 Firebase Connection
To start with this project, You need the following components:
- esp8266(NodeMcu v3 Lua)
- google account (firebase)
You can buy a esp8266 from here:
STEP 1: Setting Up Arduino IDE, Install Esp8266 Board:
Open Arduino IDE > File > Preferences > additional Boards Manager URLs > "http://arduino.esp8266.com/stable/package_esp8266c...> OK
Tools > Board: > Boards Manager > esp8266 > install
STEP 2: Setting Up Arduino IDE, Install Arduino Json Library:
Install version 5.13.1
Watch install video HERE
STEP 3: Setting Up Arduino IDE, Install Firebase Library:
Download latest stable build HERE > unzip in "Documents\Arduino\libraries"
NOTE, There is a bug in "v0.3 Bi-directional streaming support" > update fingerprint CLICK HERE FOR INFO
STEP 4: Firebase, Create Project:
STEP 5: Firebase, Project Rules:
Database(Realtime Database) > rules
/* Visit https://firebase.google.com/docs/database/security to learn more about security rules. */ "rules": { ".read": true, ".write": true } }
STEP 6: Firebase, Realtime Database Data:
Database(Realtime Database) > Data
Add: "LED1" > " "0" "
STEP 7: Code:
#include <ESP8266WiFi.h>
#include <FirebaseArduino.h>
#define WIFI_SSID "SSID" #define WIFI_PASSWORD "WIFI PASSWORD" #define FIREBASE_HOST "?????????????.firebaseio.com" #define FIREBASE_AUTH "AUTH KEY"
int LED1 = 4;
void setup() { Serial.begin(115200);
pinMode(LED1, OUTPUT);
delay(2000); Serial.println('\n'); wifiConnect();
Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH);
delay(10); }
void loop() { Serial.print(Firebase.getString("LED1") + "\n");
analogWrite(LED1, Firebase.getString("LED1").toInt()); delay(10);
if(WiFi.status() != WL_CONNECTED) { wifiConnect(); } delay(10);
void wifiConnect() { WiFi.begin(WIFI_SSID, WIFI_PASSWORD); // Connect to the network Serial.print("Connecting to "); Serial.print(WIFI_SSID); Serial.println(" ...");
int teller = 0; while (WiFi.status() != WL_CONNECTED) { // Wait for the Wi-Fi to connect delay(1000); Serial.print(++teller); Serial.print(' '); }
Serial.println('\n'); Serial.println("Connection established!"); Serial.print("IP address:\t"); Serial.println(WiFi.localIP()); // Send the IP address of the ESP8266 to the computer }
STEP 8: Code, Personal Info:
SSID > name of your wifi network
WIFI PASSWORD > password of your wifi network
FIREBASE HOST > something like "?????????????.firebaseio.com". You can find it in the "Data" tab of your Realtime Database.
AUTH KEY > Project settings > Service accounts > Database secrets
STEP 9: Esp8266 Drivers:
Click HERE > unzip and install
STEP 10: Test the Code:
use esp8266 module in board manager > click "ESP-12E module".
Open serial monitor and set it to "115200".
And you should get the same data as in your database.
12 Comments
hyu 8 months ago
Arduino: 1.8.19 (Windows 10), Board: "NodeMCU 0.9 (ESP-12 Module), 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
C:\Users\ERSHITHVARAN\Documents\Arduino\libraries\firebase-arduino-0.3\src\Firebase.cpp: In member function 'int FirebaseRequest::sendRequest(const string&, const string&, char*, const string&, const string&)':
C:\Users\ERSHITHVARAN\Documents\Arduino\libraries\firebase-arduino-0.3\src\Firebase.cpp:76:1: error: no return statement in function returning non-void [-Werror=return-type]
76 | }
C:\Users\ERSHITHVARAN\Documents\Arduino\libraries\firebase-arduino-0.3\src\Firebase.cpp: In member function 'void FirebaseStream::startStreaming(const string&, const string&, const string&)':
C:\Users\ERSHITHVARAN\Documents\Arduino\libraries\firebase-arduino-0.3\src\Firebase.cpp:89:16: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
89 | analyzeError("STREAM", status, path_with_auth);
C:\Users\ERSHITHVARAN\Documents\Arduino\libraries\firebase-arduino-0.3\src\FirebaseArduino.cpp: In member function 'String FirebaseArduino::push(const String&, const ArduinoJson::JsonVariant&)':
C:\Users\ERSHITHVARAN\Documents\Arduino\libraries\firebase-arduino-0.3\src\FirebaseArduino.cpp:65:54: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
65 | int status = req_.get()->sendRequest(host_, auth_, "POST", path.c_str(), buf);
C:\Users\ERSHITHVARAN\Documents\Arduino\libraries\firebase-arduino-0.3\src\FirebaseArduino.cpp: In member function 'void FirebaseArduino::set(const String&, const ArduinoJson::JsonVariant&)':
C:\Users\ERSHITHVARAN\Documents\Arduino\libraries\firebase-arduino-0.3\src\FirebaseArduino.cpp:94:41: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
94 | req_.get()->sendRequest(host_, auth_, "PUT", path.c_str(), buf);
C:\Users\ERSHITHVARAN\Documents\Arduino\libraries\firebase-arduino-0.3\src\FirebaseArduino.cpp: In member function 'void FirebaseArduino::getRequest(const String&)':
C:\Users\ERSHITHVARAN\Documents\Arduino\libraries\firebase-arduino-0.3\src\FirebaseArduino.cpp:101:41: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
101 | req_.get()->sendRequest(host_, auth_, "GET", path.c_str());
C:\Users\ERSHITHVARAN\Documents\Arduino\libraries\firebase-arduino-0.3\src\FirebaseArduino.cpp: In member function 'virtual void FirebaseArduino::remove(const String&)':
C:\Users\ERSHITHVARAN\Documents\Arduino\libraries\firebase-arduino-0.3\src\FirebaseArduino.cpp:147:41: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
147 | req_.get()->sendRequest(host_, auth_, "DELETE", path.c_str());
C:\Users\ERSHITHVARAN\Documents\Arduino\libraries\firebase-arduino-0.3\src\FirebaseHttpClient_Esp8266.cpp: In member function 'virtual void FirebaseHttpClientEsp8266::begin(const string&)':
C:\Users\ERSHITHVARAN\Documents\Arduino\libraries\firebase-arduino-0.3\src\FirebaseHttpClient_Esp8266.cpp:47:50: error: no matching function for call to 'begin(const char*, const char [60])'
47 | http_.begin(url.c_str(), kFirebaseFingerprint);
In file included from C:\Users\ERSHITHVARAN\Documents\Arduino\libraries\firebase-arduino-0.3\src\FirebaseHttpClient_Esp8266.cpp:9:
C:\Users\ERSHITHVARAN\Documents\Arduino\libraries\ESP8266HTTPClient\src/ESP8266HTTPClient.h:166:10: note: candidate: 'bool HTTPClient::begin(String, uint16_t, String)' (near match)
166 | bool begin(String host, uint16_t port, String uri = "/") __attribute__ ((error("obsolete API, use ::begin(WiFiClient, host, port, uri)")));
C:\Users\ERSHITHVARAN\Documents\Arduino\libraries\ESP8266HTTPClient\src/ESP8266HTTPClient.h:166:10: note: conversion of argument 2 would be ill-formed:
C:\Users\ERSHITHVARAN\Documents\Arduino\libraries\firebase-arduino-0.3\src\FirebaseHttpClient_Esp8266.cpp:47:30: error: invalid conversion from 'const char*' to 'uint16_t' {aka 'short unsigned int'} [-fpermissive]
| const char*
C:\Users\ERSHITHVARAN\Documents\Arduino\libraries\ESP8266HTTPClient\src/ESP8266HTTPClient.h:167:10: note: candidate: 'bool HTTPClient::begin(String, const uint8_t*)' (near match)
167 | bool begin(String url, const uint8_t httpsFingerprint[20]) __attribute__ ((error("obsolete API, use ::begin(WiFiClientSecure, ...)")));
C:\Users\ERSHITHVARAN\Documents\Arduino\libraries\ESP8266HTTPClient\src/ESP8266HTTPClient.h:167:10: note: conversion of argument 2 would be ill-formed:
C:\Users\ERSHITHVARAN\Documents\Arduino\libraries\firebase-arduino-0.3\src\FirebaseHttpClient_Esp8266.cpp:47:30: error: invalid conversion from 'const char*' to 'const uint8_t*' {aka 'const unsigned char*'} [-fpermissive]
| const char*
C:\Users\ERSHITHVARAN\Documents\Arduino\libraries\firebase-arduino-0.3\src\FirebaseHttpClient_Esp8266.cpp: In member function 'virtual void FirebaseHttpClientEsp8266::begin(const string&, const string&)':
C:\Users\ERSHITHVARAN\Documents\Arduino\libraries\firebase-arduino-0.3\src\FirebaseHttpClient_Esp8266.cpp:51:60: error: invalid conversion from 'const char*' to 'const uint8_t*' {aka 'const unsigned char*'} [-fpermissive]
51 | http_.begin(host.c_str(), kFirebasePort, path.c_str(), kFirebaseFingerprint);
| const char*
C:\Users\ERSHITHVARAN\Documents\Arduino\libraries\ESP8266HTTPClient\src/ESP8266HTTPClient.h:168:70: note: initializing argument 4 of 'bool HTTPClient::begin(String, uint16_t, String, const uint8_t*)'
168 | bool begin(String host, uint16_t port, String uri, const uint8_t httpsFingerprint[20]) __attribute__ ((error("obsolete API, use ::begin(WiFiClientSecure, ...)")));
cc1plus.exe: some warnings being treated as errors
Multiple libraries were found for "ESP8266HTTPClient.h"
Used: C:\Users\ERSHITHVARAN\Documents\Arduino\libraries\ESP8266HTTPClient
Not used: C:\Users\ERSHITHVARAN\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266HTTPClient
Multiple libraries were found for "ESP8266WiFi.h"
Used: C:\Users\ERSHITHVARAN\Documents\Arduino\libraries\ESP8266WiFi
Not used: C:\Users\ERSHITHVARAN\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WiFi
exit status 1
Error compiling for board NodeMCU 0.9 (ESP-12 Module).
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
Asyhier 3 years ago
kishorek35 3 years ago
MahidharB 3 years ago
Arduino: 1.8.10 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
In file included from C:\Users\Mahidhar B\Documents\Arduino\libraries\firebase-arduino-0.3\src/Firebase.h:30:0,
from C:\Users\Mahidhar B\Documents\Arduino\libraries\firebase-arduino-0.3\src/FirebaseArduino.h:22,
from C:\Users\Mahidhar B\Desktop\firebaseexample\firebaseexample.ino:3:
C:\Users\Mahidhar B\Documents\Arduino\libraries\firebase-arduino-0.3\src/FirebaseObject.h:109:11: error: StaticJsonBuffer is a class from ArduinoJson 5. Please see arduinojson.org/upgrade to learn how to upgrade your program to ArduinoJson version 6
std::shared_ptr<StaticJsonBuffer<FIREBASE_JSONBUFFER_SIZE>> buffer_;
In file included from C:\Users\Mahidhar B\Documents\Arduino\libraries\firebase-arduino-0.3\src/FirebaseArduino.h:22:0,
C:\Users\Mahidhar B\Documents\Arduino\libraries\firebase-arduino-0.3\src/Firebase.h:86:11: error: StaticJsonBuffer is a class from ArduinoJson 5. Please see arduinojson.org/upgrade to learn how to upgrade your program to ArduinoJson version 6
Used: C:\Users\Mahidhar
Multiple libraries were found for "FirebaseArduino.h"
Multiple libraries were found for "ArduinoJson.h"
exit status 1
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
rajmohan060 3 years ago
int LED1 = 4;
into
int LED1 = D2;
And connect the LED to D2 after uploading the code.
muhammadadnantalib007 3 years ago
If this doesn't work u may have a faulty esp8266
reynaldi.octavially 4 years ago
patilmayur716 4 years ago
esptool.py v2.6
2.6
esptool.py v2.6
Serial port COM8
Connecting........_____....._____....._____....._____....._____....._____.....____Traceback (most recent call last):
File "C:\Users\lax63\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2/tools/upload.py", line 25, in <module>
esptool.main(fakeargs)
File "C:/Users/lax63/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.5.2/tools/esptool\esptool.py", line 2653, in main
esp.connect(args.before)
File "C:/Users/lax63/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.5.2/tools/esptool\esptool.py", line 468, in connect
raise FatalError('Failed to connect to %s: %s' % (self.CHIP_NAME, last_error))
esptool.FatalError: Failed to connect to ESP8266: Timed out waiting for packet header
_
please help me.
MohamedS595 4 years ago
