Introduction: Esp8266 Team Hack Twitter
Let's expand our reach and start to effecting the world. There are several services that act as a bridge for automating the world around us. We'll play with a service called If This then That.
Step 1: Credentials
If you are following our team hack, then there are some services ready to go. Load up the credentials already on your esp8266.
# load the credentials
exec(open('ifttt.py').read())
# show the webhooks
ifttt_helloworld
ifttt_too_brightIf you are not starting from one of the team hack pre-programmed esp8266s, follow this page to setup ifttt. We have setup two endpoints: `ifttt_helloworld` and `ifttt_too_bright.` These write tweets using `Value1` and `OccurredAt`.
Step 2: Tweet!
Assuming that you now have a webhook url stored in `ifttt_helloworld`, go ahead and trigger the event.
# tweet_hello_world.py
import machine
import ubinascii
import urequests
# get this device's unique id
id = ubinascii.hexlify(machine.unique_id()).decode()
print("my id is: %s" % id)
# trigger the ifttt event
urequests.post(
ifttt_helloworld,
json={"value1": id},
headers={"content-type": "application/json"})You should now see a tweet from your machine id. Neat!
Let's combine this with a previous example. Like with the other long function, write this as a file `tweet_when_too_bright.py` and then load and run. This may already be on your esp8266 if it was pre-programmed for the team hack.
# tweet_when_too_bright.py
# import some libraries
from machine import ADC
from utime import sleep
import machine
import urequests
# define the light sensor pin
light = ADC(0)
# define a threshold
threshold = 40000
# loop forever, tweeting when it's too bright
while True:
sleep(1)
if light.read_u16() > threshold:
print("it's too bright!")
urequests.post(
ifttt_too_bright,
sleep(60) # wait at least a minute before tweeting again
Load and run the `ifttt_too_bright` webhook and the function. Adjust the
threshold for your own light level if you need. `Control-c` to exit.
import tweet_when_too_bright
Step 3: Next Steps
What else can we do with this? ifttt and other similar services can connect a large number of services. You could:
- Tweet when the delivery person breaks a light beam at your front door.
- Have alexa or google home tell you when to open your shades to get natural light.
- Dim your smart lights to maintain a consistent light level.
