Esspresso Coffee Wooden Tamper Handle
Intro: Esspresso Coffee Wooden Tamper Handle
Intro:
Hi everyone,
In this instructable (My very first-able) I'm going to show how I made a replacement handle of a espresso cofee tamper from wood after the original made from PVC broke.
First I'm not a carpenter nor I have much experience in woodworking but I think I can do good.
Before starting to tell what tools should you use, I must tell you that I didn't have a wood lathe which is the most important tool in making this wood coffe tamper handle, so I made some removable parts, attachable to any drill press ( I'll make another instructable for this).
Tools You'll Need:
- Wood chisel (very sharp one, about 1 1/8 large)
- Drill press and the removable parts attached to it in order to make the lathing possible.
- A rotary tool with a variation of carbide burrs, disks and bits (you can do without these by only using chisel)
- A drill
- Drill bits and forstner bits
- Caliper micrometer (very useful but you can make it somehow without it )
- Handsaw or miter saw
Desk Grinder (to round out the nut)
Materials You'll Need:
- A piece of hardwood ( I used red oak)
- Sandpapers ( 120,150,220,330)
- Tung Oil ( you can use anything you like for finish)
- Lint free clothe for oiling
- Stainless steel nut or if you have right size thread maker you can make thread directly into wood hole
- Rapidfix Glue to glue the nut inside ( you can use equivalent but Rapidfix really rocks)
STEP 1: Find a Piece of Hardwood
Find a piece of wood and cut it about 2 inches longer than the height of the original handle. Use miter saw to have a straight cut
STEP 2: Install the Removable Parts to the Drill Press
Attach the removable parts to drill press and make sure both the top and bottom are aligned.
STEP 3: Start Giving Shape
After installing the piece of wood turn the drill on and using the tools like chisel, carbide burrs, disk etc., start giving the desired approximate shape. Remember to always back chisel on right side of the toolrest otherwise you'll probably scrap the piece of wood and hurt yourself.
STEP 4: Finalizing the Shape
STEP 5: Finish
STEP 6: Round the Nut Out
Because of the lack of space in the bottom body part of the handle, the nut must be turned out to round shape and removing as much as possible from it.
STEP 7: Make the Opening for the Nut
Using the drill press and a forstner bit about 3mm larger than the nut, make a hole in the middle of the bottom of the handle. Make sure to hold tight and straight while drilling.
STEP 8: Mount the Nut Inside the Hole
Using the two component super glue called Rapidfix (one component is powder one is liquid. HOW TO USE RAPIDFIX: CLICK HERE) to weld the nut into the hole. You remember in the previous step when I said to make the hole about 3mm larger than the nut, well you're going to pour the powder on the gap between the wood and the nut and than pour the liquid component on top of the powder about the same amount of the powder (maybe a little bit more, but be careful not to spill the liquid nor the powder on the thread because this can make harder or impossible to screw the tamper in).
16 Comments
shouldwork 9 years ago
what does the top look like after being attached to burr on your homemade lathe
ngadhno 9 years ago
i forgot to do that and we can see some tiny spots but I filled them with wood filler because I don't bother.
jmc75 10 years ago
ngadhno 10 years ago
as you said the height depends on the drill press but I would not recommend to put like to large and long pieces of wood on it because as you can see this is a small "lathe" . And it will also depend on the height of the "toolrest" .
Thanks. I'm working on to make an instructable about this. It'll be ready in a while.
amekdala 10 years ago
i like your drill press lathe :)
do u mind to share the blueprints
Here you are, I published the other instructable for the wood lathe you can go and see https://www.instructables.com/id/Drill-Press-As-Wood-Lathe/
I'm making another instructable very soon and I'll share the link with you.
I'ts easy to make it, it takes about 60 min. You'll see :)
thank you waiting
rkusari 10 years ago
Suksese :)
Falemnderit :)
dzavit 10 years ago
congratulazioni fratello mio sei grande ti auguro tanati sucesi.....
grazie benne :) (mos harro me votu :)
hunter999 10 years ago
Nice and neat job! Well done, keep it up :-)
Thanks for your encouraging comment :-)
Haha, no problem. I just noticed that this is your first, so congratulations on being featured! :-)
