Everybody's Favorite Coffeecake
Intro: Everybody's Favorite Coffeecake
When I say everybody loves this coffee cake, I MEAN EVERYBODY! This has been a hit with the cross country team, swim team and the athletes' moms. It's just as good with a cup of coffee in the morning as it is in the evening with a glass of chocolate milk! Not overwhelmingly sweet, yet not lacking any flavor, this cake is the perfect happy-medium.
STEP 1: All You Will Need!
All that you will be needing is in the picture except:
-large glass bowl
-small bowl
-oven
-cinnamon
-13x9 oven pan
-large ziplock bag
-electronic mixer (preferably Kitchenaid)
-cooking spray
-large glass bowl
-small bowl
-oven
-cinnamon
-13x9 oven pan
-large ziplock bag
-cooking spray
STEP 2: The Stuesel
-Preheat the oven to 350 Degrees
-Place graham crackers in large ziplock bag and crush with rolling pin. (or with your hands)
-Melt margarine in glass mixing bowl. Microwave 1 minute or until fully melted.
-Add 2 cups crushed graham crackers to melted butter.
-Add 3/4 cups brown sugar (tightly packed in measuring cup) and stir until mixed.
-Add 1 1/4 teaspoon cinnamon.
SET ASIDE
SET ASIDE
STEP 3: Cake Mix
-Add cake mix to bowl
-Add 1 cup water
-Add 1/4 cup oil
-Add 3 eggs
-Blend in mixer (I use the Kitchenaid but any electronic mixer will do.)
-blend 1 minute on low speed
-blend 2 minutes on medium speed
-Add 1 cup water
-Add 1/4 cup oil
-Add 3 eggs
STEP 4: Baking Time!
-Prep the 13x9 baking pan w/ cooking spray
-Pour 1/2 of the cake mix in the pan and add 1/2 of the streusel. Repeat this step once again to make another layer.
-Place pan in over (middle rack) and bake at 350 degrees for 40-50 minutes. (yes, quite a broad time span, but it varies from ovens)
-(optional) test with toothpick by dipping it in and if it comes up clean, you're good to go.
-After the timer goes off, remove from pan with a hot pad .
STEP 5: The Glorious Icing
Note: Make sure the cake has cooled before adding the icing, otherwise, it will melt it. Then it wouldn't be as tasty :(
Mix 1 cup powdered sugar with 1-2 tablespoons water
Drizzle when the cake has cooled.
You can make double the icing, but be warned, it gets quite sweet!
STEP 6: Finish It Up!
Finally, serve it! Best when hot!
Don't forget to rate and add your photos of the famous Grandma Musser's Coffeecake!
8 Comments
Vika84 11 years ago
Randomguy65 12 years ago
maltesergr8 12 years ago
Thank you!
make_it_or_leave_it 12 years ago
rstohler 12 years ago
mstohler 12 years ago
bigbearswife 12 years ago
