Firebowl !!!
Intro: Firebowl !!!
In this instruction I will show you how I how to make an unique an elegant fire bowl for your garden!
So let's get started:
At first you should check the measurements of your terrace to get an idea about the bowls size. My fire bowl has a diameter of 1,3 meters, I think that's a good size even to have a REAL fire;-)
After that you can think about the design. At first I thought about making a three-cornered fire bowl, which looks very aesthetic. But this only allows a much smaller fireplace compared to 5-corner-bowl with the same diameter. If you have a big terrace this design would look impressive!
STEP 1: The Design
Its hard to "calculate" the correct measurements, so I just used the "trial and error" method:-)
After you had constructed the single part, you should assemble it to see if the parts fit together. It helps to create a "floor" plate where the bowl can stand on.
Now its time to personalize the fire bowl. You can adjust the diameter, height, form, whatever you want. Just make sure that the parts fit nicely.
Before you do the next step, try to assemble and reassemble the parts in the computer, just like you would do it in reality!
STEP 2: Manufacturing
To produce the fire bowl you have to create an DXF-file and a rough drawing of the sheet metal. The DXF-file is needed by the CNC-machine, and with the rough drawing you can calculate the amount of sheet metal you will need.
You don't have to use stainless steel of course, normal steel, maybe with a rusty look, will also look very good and will be much cheaper!
If you are one of the lucky guys who own a CNC-mill or a CNC-plasma-cutter or something like that, you just have to send the DXF-file to your CAM-Software. If not, you have to search for a workshop which is able to cut sheet metal.
Now you just have to send the DXF-file to this company, and wait for the cut parts to arrive!
After getting the parts, just assemble it, get some firewood, cold beer and some friends and enjoy a cosy evening with your new fire bowl!
23 Comments
PavelNikolenko 5 years ago
zeroaxe 12 years ago
I got the parts cut out, but cant assemble them. My logic tells me there must be a fold somewhere, but dont see any instructions in this article. Can anyone please advise?
Thanks!
hanelyp 12 years ago
- Put the pieces almost vertical, pointed corner down, in a circle.
- Hook each one over a neighbor.
- Pivot all the bottom points in together.
dkortenbruck 12 years ago
Maybe you can send me some photos?
I will add a view of the underside. The diameter of the base is about 0,5m
trustr 12 years ago
and a great idea!
How much did it cost (with all the laser cutting etc.) ?
Captain Pedantic 12 years ago
acti 12 years ago
to the fold line..
This would allow you to stack the plates at the fold, and use a pair of
carabiners to keep the stack locked together, for shipping or carrying
between campsites.
Using slots (vs holes) makes the individual plates "universal", so you don't
care what order they are in, when stacked. (Each added plate in the stack
shifts the hole location slightly, relative to the other plates, by the thickness
of the plate stock.)
chicopluma 12 years ago
dkkim 12 years ago
Kev13 12 years ago
I'm sorry, but I don't really know what this would cost in a regular shop. I didn't had to pay for that work, because they got a new laser cutting machine and my work was the first try:-)
But I really reccomend to ask for prices at different shops!
