Introduction: Execute the Flaming Pen Prank!!!!
This April Fools, Forget about the Rubber Spider Prank, Try the Flaming Pen Prank Instead, Follow these simple steps and you'll be able to execute this prank with ease. Everyone will fall for it, Try this Under EXTREME CAUTION!!!!
Follow the link below to watch the video and see how the prank really works!!!! you wont be disappointing
http://www.break.com/usercontent/2009/4/How-To-Pull-Off-The-Burning-Pen-Prank-695712.html
Step 1: Materials!!!!
To Execute the Flaming Pen Prank, you will need the following items.
1 plastic pen
1 box of matches (2 matches per prank)
Water
(optional items) dropper, scissors/knife
Click on the link to watch the instructional video
1 plastic pen
Water
Step 2: Disassemble!!!
Step 1- Take apart the pen, Remove the Ink.... You should only be left with the Pen tube, Tip and Cap.
VIDEO
VIDEO
Step 3: Set Up!!!
Step 2- Cut out a small square from the strike pad
Step 3- Bend it and put it inside the cap
Step 4- Shorten two Matches and Push them inside the Tip of the pen
Video
Video
Step 4: CAUTION!!!!
Safety measure should be taken when performing this prank, so what you will need to do is add some water inside the pen tube, this will put out any flame.
ViDEO
ViDEO
Step 5: APRIL FOOLS!!!!
Step-5 Put everything back together (cap on pen) and leave it where you know your victim will get it.
HOW IT WORK? When the cap is removed from the pen, the piece of that strike pad inside the pen, will light the matches, causing flames to come out of the tip of the pen, ( the unexpected flames will scare your victims silly)
Weather they drop the pen or just hold it in their hand, the water you put inside will put out the flame in a matter of seconds......
Watch The Instructional Video by Clicking on the Link Below.... You will see the full results....
