Exhaust Manifold Replacement (Honda Civic 1999 D15B Engine and EK3 Chassis)!
Intro: Exhaust Manifold Replacement (Honda Civic 1999 D15B Engine and EK3 Chassis)!
My honda civic 1999 D15B engine has had a long crack in its exhaust manifold. I read this is a common mode of failure for my vehicle model.
Time to replace with a performance manifold!
Please note that in my country there is no emissions testing. This installation is perfectly legal where I am. If You need to pass emissions testing then you should not install one of these manifolds.
The manifold in question I purchased from Amazon for 62us.
Honda Civic Ex Crx Del Sol Sohc Dynamik Header 2 Pc. - http://www.amazon.com/gp/aw/d/B0089UEOKA/ref=mp_s...
STEP 1: Removing the Old Manifold.
Safety first as always. I used ramps on my Front wheels, handbrake up, rear wheels chocked, wear gloves.
The old manifold and heated oxygen sensor were easy enough to remove using the O2, 14mm and 12mm sockets with Rachet.
You will notice the long crack at the oxygen sensor location. Exhaust and steam used to actually geyser out of this. I read that this crack would cause the sensor to fail early but I'm not so sure about that.
STEP 2: Comparison of Oem and New.
STEP 3: Installing the New Gasket
STEP 4: Assembling the New Manifold.
The entire manifold needs to be assembled prior to going into the car. The inter gasket and bolts all need to be installed properly. Trying to make this bolted connection after putting the manifold on the car is near impossible.
STEP 5: Installing the Manifold.
Here is the trouble part. The new manifold is 2 inches short to the muffler pipe. I had to use a long enough nut and bolt (actually a spare u clamp) through one hole.
The spring loaded bolt I ran into the other hole and used a g clamp to squeeze the spring to allow me to thread the nut. The other bolt for the first hole was easier.
STEP 6: The Completed Job.
My shiny exhaust manifold shall assure my entrance into Valhalla!
9 Comments
myr1 8 years ago
Nice write up. I'm doing this on my EK next week :-)
★ Sign: 007 License Plate Hide Gadget: http://007Plate.com ★
Mjtrinihobby 8 years ago
victorg6546 8 years ago
swander 8 years ago
stuckindmud 8 years ago
Ninjarooster 8 years ago
