Introduction: Explore Shibori Dyeing- Kumo Dye a Silk Scarf
Explore Shibori Dyeing - Kumo Dye a Silk Scarf
Gosh, I love playing with colors! Always have! And exploring the many various cloth, fiber and yarn dyeing techniques is a neverending fascination for me.
So, what is Shibori Dyeing anyway? Shibori is really what tie-dyeing is based on. Here’s what Wiki says: “There are an infinite number of ways one can bind, stitch, fold, twist, or compress cloth for shibori, and each way results in very different patterns. Each method is used to achieve a certain result, but each method is also used to work in harmony with the type of cloth used. Therefore, the technique used in shibori depends not only on the desired pattern, but the characteristics of the cloth being dyed. Also, different techniques can be used in conjunction with one another to achieve even more elaborate results.” Here’s my version of dyeing a silk scarf with the Kumo Shibori method which involves pleating and binding.
Step 1: Supplies
-Silk Scarf
-Jacquard Acid Dye – Pink
-Synthetic Thread or Unwaxed Dental Floss
-Vinegar
For Setting the Dye you need:
-Pot or Pan (not used for food)
-Stove or Hot Plate
-Water
Pre-treating:
Warm up a cup or two of vinegar and soak your silk scarf for about 30 minutes. This will help set the dye. Folding & Tying: Take the scarf out of the vinegar bath and squeeze out excess liquid. Now, fold it in half lengthwise and then fold it again. Pull up a random area of the scarf (all 4 layers) and tightly tie the string around it in spiral fashion. Repeat in one or two more spots, depending on the size of your silk.
Step 2: Folding & Tying
Step 3: Dyeing
Mix up your dye according to package directions. Put some warm water in the pot, then add about 1/4 to 1/2 cup of the liquid dye. Place the scarf in the dyebath and gently move it around to cover each part. Let it sit and absorb the dye for about 30 minutes.
Turn the heat to Medium until it just starts to simmer, then heat for about 45 minutes. Turn off the heat and carefully remove the scarf. Untie and rinse well with warm water.
Step 4:
There you have it! A beautiful, one-of-a-kind Silk Scarf. This would make a lovely gift as well!
Stay tuned…. there are lots more Shibori Dyeing techniques to explore!
Lots more fun Tutorials at Fiberartsy.com!
If you enjoyed this, please share it!
Have a fabulous day!
Annette
Fiberartsy
4 Discussions
5 years ago
That is gorgeous! Shibori looks so awesome. I love it. :)
6 years ago on Introduction
Beautiful!
This looks lovely :-)
