Introduction: Explosive Knex Knife Thrower
A simple yet devestating close range knife thrower with exsplosive fragment rounds.
I made this when i built a model of a medieval magonel
when the arm flew off!!!
Step 1: Collecting the Pieces
Well I bet everybody can figure this out in the picture
Step 2: Constructing the Frame
Just follow these simple pictures!
Step 3: Adding the Rubberbands
Use two durable thick rubberbands and wind them around towards the handle, then when the tension builds up add a yellow rod as shown.
Step 4: Loading and Firing
To load clip a normal shot(no rings) or a exsplosive one (with rings) into the yellow connector. Then pull back the shot like cocking a gun the slip your finger off. If it does not fire try adding more rubberbands.
You can also clip a white rod on the yellow connector and put any slip any knex pieces with a hole and fire.
Step 5: MY OTHER INSTRUCTABLES
Please take a look
https://www.instructables.com/id/EVW12CKDK8EV2Z4COS/ Heavy crossbow
https://www.instructables.com/id/EV15SL4DFWEXCFMVSA/ Grenade
https://www.instructables.com/id/ECGX2R7W5NEV2Z4O0I/ Knex Crossbow
https://www.instructables.com/id/ED9JQ1UEUQEYSYVDH2/ Knex Uzi
