External Guitar Amp Speaker
6,490
20
Introduction: External Guitar Amp Speaker
Is your amp crap? Not enough bass? Bad quality? Have you ever wanted to connect your subwoofer or other speaker to your guitar or bass amp but haven't had the equipment to do so? Well it's easy.
Required parts:
-speaker/subwoofer
-screwdriver
-wire
-amp (I'm using my first act MA214 amp)
Using both speakers may drive power from the original speaker
Step 1: Unplug and Gain Access to Main Amp Speaker
For my amp all I had to do was remove the back
Step 2: Detach Speaker
Remove all of the screws holding the speaker in and remove it.
Step 3: (optional) Remove Speaker From Amp
Unplug the wires and discard speaker
Step 4: Attach/Solder Wires to Speaker
You can can completely get rid of the main speaker or you can have the amp powering both speakers, I choose to use both speakers.
Step 5: Reassemble and Run Cord Through the Tuning Hole
Reassemble the amplifier and run the cord through the tuning/air hole
Step 6: Connect Wires to Desired Speaker/subwoofer and Enjoy!
Well... Connect your wires to the speaker/sub you want to use
Step 7: (optional) Cover Cord With Corner Pad
As you can see in the image I took of the corner padding and ran the cord under it to hold the wire down so nothing could rip it from the speaker on accident
Step 8: And You Fine Sir or Ma'am Are Done
Be the First to Share
    • Lamps Challenge
      Lamps Challenge
    • Puzzles Challenge
      Puzzles Challenge
    • Rice & Grains Challenge
    2 Comments
    tbirkhofer
    tbirkhofer
    7 years ago
    It really does! Thank you!
