Eye Props
Intro: Eye Props
On the last step I have put up pictures of the eyes. Please comment if you have any tips and vote if you like it =)
Last year I did my first instructable. This year I will start up with a new Eye. Fast to make and its all in your imagination what you do with it.
A lots in this instructable is visual so not much text to read. Ask and I will answer if you wonder.
This you need:
Watercolor
Water
Brusches, at least one hard
Sharp knife
Old DVD/CD
Plastic Wrap
Permanent Marker, sharp tip
Cotton Wool ball
Toilet paper or something like it
Tothpics
Latex
A box
Cutting board
This you need:
Watercolor
Water
Sharp knife
Old DVD/CD
Plastic Wrap
Cotton Wool ball
Tothpics
Latex
A box
Cutting board
STEP 1: Latex the Ball
I coat the ball with one layer of latex. When dried I make another layer that I coat with some paper, the more work you put in, the more imagination you have the happier you will be.
STEP 2: Plastic Wrap
This is how I did the Iris.
As image shows I have painted some already, it became a bith thick line but nothing gets perfect first times around and I have ten more to do.
I cut a hole in the plastic wrap using a sharp knife and my old dvd. Put it over my soon to be eyeball.
STEP 3:
I now use a brush, a hard one, to spray some color on the eye as iris. On this I used green and blue and just one spray of red. I also used a line of red just to see what I could do.
Amount of layers sprayed will effect the outcome as you will see on my next step where I have two made this way.
STEP 4: The Outcome
On the one featured in this instructable I did not use paper all over, on the yellow I coated it and crumbled it all over with more work into it.
Takes around the time to get latex to dry between to make this.
Fast n easy.
Fast n easy.
STEP 5: More Pictures
The eyes =) Im not a expert painter and theese are like a huge experiments with every eye, but watercolor has alots of pigments in it so once its on you cant remove it. But you can use more color =) and as it is halloween groose it out is easy.
When using theese at halloween they will be with more blood and so so I will add some end pictures after Halloween =)
Good Luck and have fun :=)
11 Comments
friendlysinger 12 years ago
Suizezem 12 years ago
cgrone 12 years ago
cgrone 12 years ago
They turned out great. I tried it with some Sculpey clay as well and this is what came up with. Fast and realistic. I added some Liquid latex to mine and tore it a little to give it the effect of a torn pupil. I found that Clear Elmers Glue gives you a nice sheen and glossy effect as well as seals the eyes.
scoochmaroo 12 years ago
mary candy 12 years ago
l8nite 12 years ago
