Ez Arduino MiniKame Mk2 - Making a 8 DOF 3D Print Quadruped Robot
22,151
86
78
Introduction: Ez Arduino MiniKame Mk2 - Making a 8 DOF 3D Print Quadruped Robot
About: We love robotics!
This is an inexpensive 3D printed 8 DOF quadruped robot using Arduino kind control board. It has two playing modes. One is autonoumose pilot mode which the robot walks and performs action randomly. The other is control mode where the robot is controlled by iPhone or Android phone via BLE technology.
This instructable page contains detail of steps in sequence of videos to people who are interested to build one.
Step 1: Printing 3D Models
You can download the 3D printed STL models here. Those samples are printed in PLA. Suggested parameters for slicing the models to print are as followings. You may adjust them to fit the 3D printer you're using.
  • bottom/top thickness: 1mm
  • shell thickness: 1.2mm
  • layer height: 0.2mm
  • fill density: 10%
  • support: yes
  • adhesion type: skirt or brim
If you don't have a 3D printer, you may find online 3D print service.
Step 2: Software
Robot Code -
  • Arduino code on githup
  • uploading the Arduino code by open firmware.ino in the Arduino Software, see step 10 on IOS app and step 11 on Android app to control the robot;
for HuaDuino, in Arduino IDE software:
  • the board selection: "Arduino Nano", processor "ATmega328" for AVR Boards support version 1.6.20 or older;
  • the board selection: "Arduino Nano", processor "ATmega328 (Old Bootloader)" for AVR Boards support version 1.6.21 or newer.
Control Apps -
  • goBLE - IOS app on Apple Store;
  • playBLE - Android app on Google Play;
  • virtual-gamepad-BLE - Android app contributed by a supporter, for Android 5.0 and latest;
  • virtual-gamepad-SPP Android app contributed by a supporter for HC-06, HC-05 and SPP-CA classic Bluetooth 4.0 SPP module; compatible to Android 4.0 and above;
Step 3: Electronics Components
    The electronic components can be found in online store such as ebay, amazon, aliexpress and etc.
    Main -
    • a HuaDuino board, it is Arduino Nano compatible with enhanced features. It integrates everything on a single PCB. It's a lot easier for people to make a bot with it. Embedded battery charging circuit, battery charging is more convenient. It can be found on Amazon.
    • a single 3.7V 18650 lithium ion battery or battery pack with XH2.54 connector, if you want longer running time getting a pack with two 18650 in parallel. You may like to use this 18650 battery holder. However, it is also fine to use 3.7V 10440 lithium ion and 3.7V lithium polymer battery dimension not bigger than W35mm, L70mm & T60mm. The photo is with two 10440 lithium batteries in parallel.
    • 8 x Tower pro MG90s/compatible.
    • a female-female dupoint wire or anything you can figure out for connecting two pins;
    • some m2x6 tapping screws
    Bluetooth Module - this module is optional if you don't need App control
    • a HC-06, HC-05 and SPP-CA classic Bluetooth 4.0 SPP module - if you use this type of Bluetooth module, it must use the virtual-gamepad-SPP Android app for control; baud rate must be set to 115200; see this tutorial to configure the baud rate using AT commands;
    • Or
    • a BT-05 CC2540 Bluetooth LE module - there are many BLE modules named differently, but they are built with CC254x chip. Examples such as HM-10 and CC41-A are the typical you can find in the market. Since the firmware is different, the AT command set may vary too. You may use this code to identify them. To work with the robot code and the apps, baud rate is required to set to 115200; service UUID must set to 0xDFB0 and characteristic UUID must set to 0xDFB1 using the AT commands. Below is the code intended to do that automatically but it may not work if you have different one.. The reference of the AT command set to configure BT-05 BLE can be downloaded here. You don't need this module if you like to make this gamepad to control and play.
    • Below only required for Bluetooth LE module
    The following Arduino code issues AT commands setting BLE module UUID, characteristic and baud rate, assuming the BLE default baud rate is 9600. For running this program in HuaDuino with the module onto it, the S1 switch must be set to the BT position.
    void setup() {
      Serial.begin(9600); //change to fit your ble initial baud_rate
      Serial.println("AT+UUID0xDFB0\r"); // uuid
      delay(50);
      Serial.println("AT+CHAR0xDFB1\r"); // characteristic
      delay(50);
      Serial.println("AT+BAUD8\r"); // set baud rate to 115200
    void loop() {}
    The steps you should do of uploading the Arduino sketch to HuaDuino for BLE control are as following
    1. insert the BLE module, switch S1 to USB side, turn on huaduino,
    2. uploading the above ble module setup program
    3. turn off huaduino, switch S1 to BT side
    4. turn on huaduino, let the ble module setup program run in few seconds.
    5. switch S1 to USB side
    6. uploading the robot code by open "firmware.ino"
    7. switch S1 back to BT side, the robot now can be controlled by BLE
    Step 4: Installation of Servos and the Control Board
    Step 5: Legs
    Step 6: Servo Wiring
    Connection to digital pins of HuaDuino are as followings:
    • D2 to front right hip servo
    • D3 to front right leg servo
    • D4 to back right hip servo
    • D5 to back right leg servo
    • D6 to back left hip servo
    • D7 to back left leg servo
    • D8 to front left hip servo
    • D9 to front left leg servo
    Step 7: Calibration
    Using a du-point wire between D12 and 3.3V pin, the robot servos will be set to default angle and in stance position. This is the status for installing servos and having servo arm capping on the correct angle.
    Step 8: Installation of Servo Arms
    while the du-point wire connected between D12 and 3.3V pin, puts the servo arms to the servo shaft
    Step 9: Finishing Up
    insert the CC2540 Bluetooth BLE module to the board's Bluetooth connector, and slide the S1 switch to the BT side (ignore this step for new version of HuaDuino), finally closes the robot with the top cover.
    Step 10: Plays Using IPhone
    To success doing this part, you must configure CC2540 Bluetooth BLE module, see the step 3 - electronics components
    • opens the iOS app and closes it the robot,
    • after few seconds the BLE paring between the robot and iPhone should be done. You will see the connection symbol changed to green.
    • press the top middle virtual button will switch the robot to control mode, and press again will turn back to autonomous self walking mode.
    Step 11: Plays Using Android Phone
    • open the Android app while robot is on pressing the connection symbol closed the top edge.
    • after few seconds you should see listed BLE device and
    • select it and connection symbol should turn to blue when successes
    • press the top middle virtual button it will switch to control mode and press again it will back to autonomous self walking mode
    Step 12: Battery Charging
    • plugs a 5V power source micro USB cable to the robot USB port
    • a red light indicates charging
    • a green light indicates charging completed
    Microcontroller Contest
    Runner Up in the
    2 People Made This Project!
    • Battery Powered Contest
    • Plywood Challenge
      Plywood Challenge
    • Plastic Contest
      Plastic Contest
    78 Discussions
    rossank
    rossank
    Question 2 months ago
    hello I'm trying to do the hexapod but the link to see the instructions no longer works. Where can I find it? Thanks in advance and congratulations on the projects
    DIRETE
    DIRETE
    7 months ago
    Hey dude a great job doing this tutorial but i have a problem, im triying to downlowad the virtual gamepad SPP but it says that the link isnt available because you eliminate the app from your drive, could you help me please?
    injobho
    injobho
    Question 7 months ago
    I have a designed a new design of 8 dof robot like yours but some servos are to be reversed. I am a bit new to arduino but your code is running and moving the legs exept a few moving opposite direction. Can you please guide me how to reverse the direction of any servo ?
    rl102004
    rl102004
    Question 8 months ago
    Is there a substitute for the virtual gamepad SPP? Everytime i try to download it, it says that it doesn't exist.
    rl102004
    rl102004
    Reply 8 months ago
    Sorry, but it doesn't work. But thanks for trying.
    rl102004
    rl102004
    Question 11 months ago
    I got everything done, but which code do i use and how do I upload it to the it? It keeps saying error everytime I try.
    manic-3d-print
    manic-3d-print
    Answer 11 months ago
    if you bought the latest version of HuaDuino, this video demo how to upload the code.
    rl102004
    rl102004
    Reply 11 months ago
    Thank you, now there is no error. Also which one is the correct code to use because it keeps saying as well that the code is filled with incorrect commands and mine doesn't have a second switch to it.
    lilysgrampa
    lilysgrampa
    Question 1 year ago on Step 12
    Well I have it made (using HauDuino) and in auto mode it runs fine (grandkids love it) and now I'm trying to connect with an iPhone (using GoBLE). I have an AT-09 !!! Android IOS BLE 4.0 Bluetooth module for arduino CC2540 CC2541 Serial Wireless Module compatible HM-10 but while I can use AT commands to change the baud rate, I can't change the UUID or CHAR. They are UUID=FFE0 and CHAR=FFE1. Any suggestions?
    version=5.3
    manic-3d-print
    manic-3d-print
    Reply 1 year ago
    some firmware version does not take "0x" as hex number prefix, for AT+UUID and AT+CHAR commands, you may try AT+UUIDDFB0 and AT+CHARDFB1
    lilysgrampa
    lilysgrampa
    Reply 1 year ago
    Unfortunately that doesn't work eithor. Is the UUID DFB0 a coded value or something in the HuaDino board?
    manic-3d-print
    manic-3d-print
    Reply 1 year ago
    0xDFB0 and 0xDFB1 are the values of service UUID and characteristics UUID in BLE module., ios app looks for them to make the connection.
    lilysgrampa
    lilysgrampa
    Reply 1 year ago
    Thanks, so to make sure I understand, if I can't change the UUID and CHAR, I'd have to change the GoBle code (which I can't) to get this to work.
    Now to try to find a AT-09 that allows you to change the UUDI/CHAR...
    p.s. my grandkids love the robots.
    If anyone knows where I could get one I'd be very appreciative :>)
    manic-3d-print
    manic-3d-print
    Reply 1 year ago
    you must change UUID and CHAR as they are values in BLE module, not any parts of the robot code.
    ib22861
    ib22861
    1 year ago
    im having trouble with code so I downloaded the firmware code and i copied and pasted the other codes into other tab and im getting compiling errors and exit statuses
    manic-3d-print
    manic-3d-print
    Reply 1 year ago
    download the zip from github, and open minikame.ino in arduino ide software after unzip
    patty87
    patty87
    1 year ago
    I can upload the program to the bot, and the app connects to the bot, but the controls do not make the bot move at all.
    ib22861
    ib22861
    Reply 1 year ago
    the program doesnt work for me how did you get it to work it just says undefined rerefrence to minkame
