Introduction: FACE SHIELD PPE
Super easy PPE face shield. Can be re-used and sterilized. Minimum supplies needed, you can dl the pattern and hand cut or the svg and use a cutting machine
1 OHP acetate - or other suitable clear film
1 polypropylene file divider
5 small tie wraps - or double sided sticky tape
hole punch
SVG file for machine cutting
Step 1: Make the Face Part
sandwich the acetate between the two to strips
you can use double sided sticky tape or fasten with the tie wraps if you want to be able to sterilize the shield and re-use
Step 2:
fasten with tie wraps, trim the ends. the front mask piece fastens to the back strip - the back strip is the part that lays across your forehead.
