Introduction: FRANKENSTEIN CAMP BUCKET LIGHT
BUCKET
I USED A 5 GALLON BUCKET FROM MENARDS AND LACQUER THINNER TO REMOVE ALL WORDING ON BUCKET. I BOUGHT THE LID FROM HOME DEPOT--THE ONLY PLACE I COULD FIND WITH A BLACK LID. AFTER MASKING OFF THE SURFACE, PAINTED THE TOP RIM BLACK WITH SPRAY PAINT.
FACE
CREATE A FACE--THE MOST DIFFICULT PART WAS GETTING THE RATIOS OF THE FACE, HAIR, AND EARS CORRECT--PRACTICED WITH PAPER UNTIL IT LOOKED RIGHT. CUT IT OUT WITH A VINYL CUTTER AND APPLIED TO BUCKET.
NECK BOLTS
RUMMAGED AROUND AND FOUND A COUPLE OF OLD ROLLERS AND ATTACHED USING A BOLT AND WING NUT TO THE SIDES. MOST ANYTHING WOULD WORK--SPOOLS, ACTUAL BOLTS....
LIGHT
INSERTED AN LED PUCK LIGHT WITH REMOTE INTO BUCKET AND USED THE WHITE LIGHT SETTING.
I HAVE ALSO MADE SOME BUCKET LIGHTS WITH DIFFERENT SCENES--CEMETERY, BATS, AND JACK-O-LANTERNS AND HAVE TRIED WHITE BUCKETS USING THE DIFFERENT COLORS OF THE PUCK LIGHT AND IT WORKS FAIRLY WELL.
5 GALLON BUCKET WITH LID (MENARDS AND HOME DEPOT)
BLACK PAINT FOR TOP PART OF BUCKET
VINYL SHEET FOR FACE, HAIR, EARS, AND SCAR
ROLLER, TUBE, BOLT, WASHER FOR NECK BOLTS
LED PUCK LIGHT WITH REMOTE (AMAZON)
Halloween Contest
2 Comments
2 years ago
Thanks for sharing!
You should consider breaking your information out into steps, it can help make following along with the tutorial easier :)
Reply 2 years ago
Thanks--that was the first time I have done one for Instructables--if I do another I will!
