Introduction: FX-9 (TAW) or Tactical Assault Weapon
Here is the FX-9 Tactical assault weapon. This gun was designed as an all purpose weapon. It started out as my folding gun which you can see Here. .It didn't fire over 5 feet so I took it and tried to make it a sling shot. That didn't work either so I took it apart and made this. One of the things I like about it is that you can shoot any thing from a killerk bullet to a grenade and even a some of IaC's bullets. Another thing I like about it is the short trigger pull, and the smooth body as in no blue rods sticking out. The range depends on the bullet you use. I'll leave it up to you to decide if it's any good of not. Keep in mind the bipod type thing won't be it the instructions I just used it to keep it upright.
If it sounds good let's get a building.
Step 1: Part Count
On big guns like this you don't want to get 3/4 way done and run out of pieces. So I went and made a part count for everyone.
Connectors:
White 27
Blue 4
yellow 130 and 12 tabed
purple 2
green 13 (ooooo)
red 6
acute 6
orange 37
gray clip 4
Rods:
red 6
blue 8
white 110 (one needs to be cut.)
green 300
Odds and ends
black hands 30
Keep in mind these are not exact but close.
Connectors:
White 27
Blue 4
purple 2
green 13 (ooooo)
red 6
acute 6
orange 37
gray clip 4
Rods:
red 6
blue 8
green 300
Odds and ends
black hands 30
Step 2: Front of the Gun
The instructions are pretty basic.
Step 1: Build two of these.
Step 2: Add orange connectors.
Step 3: What you should have.
Step 3: Barrel
Just build this.
Step 4: Bottom of the Gun
Step 1: build all this and gather 4 white rods and 1 blue rod.
Step 2: put it all together.
Step 5: Put Together the Front
Step 1: take the side panel with orange connectors and add the part in step 4.
Step 2: now add the part made in step 3
Step 3: add the other side
Step 6: Back of the Gun
Step 1: Make 2 of these.
Step 2: add the blue rods and orange connectors.
Step 7: Make These
Here are some random parts. such as handle, trigger, etc.
Pic 1-2: handle
Pic 3: make this it will be the trigger.
Pic 4: this will be the ratchet.
Pic 5: make these parts
Pic 1-2: handle
Step 8: Putting the Stock Together
Step 1: on the panel with the blue rods and orange connectors add this part.
Step 2: add the ratchet
Step 3: add the handle
Step 4: In the next three pictures add the parts that are shown
Step 5: This is what you should have
Step 6: add the other panel
Step 7: add these three yellow connectors in the butt.
Step 9: Put the Front and Pack
just put the two parts together.
Step 10: Loading and Firing.
Put the rubber bands on the trigger.
put rubber bands on the barrel.
now to shoot the killerk type bullet, just string the bands on the tan clip and hook into the y connector.
to shoot the larger ammo hook the rubber bands on the y connector, set the ammo on top of the bands and pull the trigger.
Hope you all like.
If you have any problems let me know on my orangeboard.
Hope you all like.
