Face Detection Using Python and OpenCV Library
Intro: Face Detection Using Python and OpenCV Library
This project will use the OpenCV library and python to facilitate face detection
STEP 1: What You Need
1. An Intel Edison Development Board
2. A webcam, we will use the Light Wave LW-IC500
3. Python and the openCV library installed on your machine
STEP 2: Setting Up
The Intel Edison board has an inbuilt USB port, through which you can connect your webcam. This will provide power and get images from the camera.
Also, connect the Edison to your computer through the provided USB Cable in order to upload programs. Make sure your putty is running well, and is connected to the board
STEP 3: Your Code:
import numpy
import cv2 import urllib print("Downloading Images and Necessary Files") urllib.urlretrieve('http://cdn.makezine.com/make/43/Intel_CES_Team.png', '/usr/lib/edison_config_tools/public/in.jpg') urllib.urlretrieve('https://raw.githubusercontent.com/Itseez/opencv/master/data/haarcascades/haarcascade_frontalface_alt.xml', '/usr/lib/edison_config_tools/public/haarcascade_frontalface_alt.xml') img = cv2.imread('/usr/lib/edison_config_tools/public/in.jpg') gray = cv2.cvtColor(img,cv2.COLOR_BGR2GRAY) faceCascade = cv2.CascadeClassifier('haarcascade_frontalface_alt.xml') faces = faceCascade.detectMultiScale(gray,scaleFactor=1.1,minNeighbors=5,minSize=(30, 30), flags = cv2.cv.CV_HAAR_SCALE_IMAGE) for (x,y,w,h) in faces: cv2.rectangle(img,(x,y),(x+w,y+h),(255,0,0),2) cv2.imwrite('in_face_found.png',img)
STEP 4: Try It Out
Log on to your html page and check the results out
3 Comments
noorthamer 7 years ago
hello sir ^^
please do you have the algorithim of object track by python ??
seamster 8 years ago
Very interesting, thanks!
Would you use a face detection feature like this for security purposes, or for something else?
robopathshala 7 years ago
https://www.instructables.com/id/Face-Detectionrecognition/
