Fainting Fancies
Intro: Fainting Fancies
This version of the Weasleys' trick sweet uses the idea of a double shock to add magic to its gummy goodness. Firstly, the savory orange colored "fainting" side takes the eater by surprise with the completely unsweetened flavor of carrot spiced with cumin. Then the sugar-laced yellow half, meant to revive it unconscious consumer, tastes of sour lemon.
STEP 1: Supplies
4 Tbsp unflavored gelatin
4 Tbsp water
1/3 cup carrot juice, strained (other juices work here)
1/4 teas ground cumin
1/3 cup apple juice
6 Tbsp sugar
1 packet lemonade flavored drink mix powder, unsweetened (1/4 oz)
1 small pan*
*Total volume is 1 1/4 cup so I used a mini loaf pan 5"X3" To see how thickly your treats will be in your own small pan, pour in 1 1/4 cups to see the final height.
4 Tbsp water
1/3 cup apple juice
6 Tbsp sugar
1 small pan*
STEP 2: Non-Sweet Side (Orange Colored)
Place 2 Tbsp water into a small bowl. Add 2 Tbsp gelatin. Set aside for at least 5 minutes.
In a small saucepan, place 1/3 cup carrot juice and 1/4 teas cumin (other juices/spices will also work). Heat on low-medium to simmering. Add the gelatin. Stir until gelatin is melted.
Pour into pan and place in refrigerator to chill. Once it is set-up and cool, about an hour or so, proceed to the next step.
STEP 3: Revival Side (Yellow)
In a small saucepan, place 1/3 apple juice, 6 Tbsp sugar, and contents of drink mix packet. Heat on low-medium while stiring until sugar is dissolved. Add the gelatin. Continue stirring over low to medium heat until gelatin is melted.
Set aside while this mixture cools a little. It should still be warm but not so hot it will immediately melt the cooled orange side. I set it out for about 15-20 minutes but your experience may vary. Carefully pour over orange gelatin and place in refrigerator to chill and set-up.
STEP 4: Cutting
One the two layers are set-up, place the pan in hot water and carefully loosen sides with a knife. Turn out onto a slightly damp cutting board (this prevents it from sticking so much).
Keep a bowl of hot water handy. Plunge the knife into this water between cuts, allow it to be hot and wet as you slice through. Slice off a side, as shown. Using a knife or cookie cutter (also plunged into hot water) to cut the candy into pieces. If uneven, trim them to even them up.
Allow these candies to sit out on a very lightly greased plate for an hour or two to lose their stickiness. Keep packaged between layers of parchment paper in the refrigerator. Since the carrot side is completely unsweetened, it should be kept cold. So if you happen to make two sweet sides, refrigeration is not necessary.
6 Comments
ilex98 10 years ago
timmycutts 12 years ago
pyro1234567890 12 years ago
TheGeek1984 12 years ago
starshipminivan 13 years ago
SewWhat!! 13 years ago
