Introduction: Farmhouse Rustic Crochet Round Jute Placemat
Crochet Patterns made with Jute twine are beautiful to look at and they are extremely strong , durable and sturdy. They add a beautiful rustic feel to the finished projects. There are various projects you can make with a just twine. They work the best for everyday use projects like Bags, Baskets, Rugs and Placemats.
Today am sharing the pattern for Farmhouse Rustic Crochet Round Jute Placemat. This is a part of the 2023 Giftstravaganza Blog Hop which is being hosted by Marie from Underground Crafter. The Pattern is easy to go made with simple stitches. This placemat will be great for adding a chic element to your table setting.
You might find the Jute twine a bit rough and scratchy on your fingers to work with. Hence I used a Crochet Tension Ring. They are just awesomely smooth and easy for making the crochet stitches. Its fun and worth making Crochet Projects with Jute Twines and Cords.
14 Inches - can be customized to any size
Visit https://rajiscrafthobby.blogspot.com/2023/11/farmhouse-rustic-crochet-round-jute.html
2 Ply Jute Twine Cord
5 mm Crochet Hook
Step 1:
Here is the Video Tutorial:-
You can follow along with this tutorial video. Please be sure to subscribe too!
Step 2:
Round 1:-
Start with a Magic Circle.
12 Double Crochets in the circle.
Pull the yarn end to close the gap.
Slip Stitch on top of the first Double Crochet.
12 Stitches.
Step 3:
Round 2:-
Chain 2.
2 Double Crochets in each stitch around.
Slip stitch on top of the first Double Crochet.
24 stitches.
Step 4:
Round 3:-
Chain 2. 1 Double Crochet in the same stitch.
2 Double Crochets in the next stitch.
Repeat*(1DC, 2DC).
36 Stitches.
Step 5:
Round 4:-
Chain 2.
1 Double Crochet each in 2 stitches.
Repeat*(1DC*2, 2DC)
48 Stitches.
Step 6:
Round 5:-
Chain 2.
1 Double Crochet each in 3 stitches.
Repeat*(1DC*3, 2DC)
Change color while making the slip stich.
60 Stitches.
Step 7:
Round 6:-
Chain 2.
1 Double Crochet each in 4 stitches.
Repeat*(1DC*4,2DC)
72 Stitches.
Step 8:
Round 7:-
Chain 2.
1 Double Crochet each in 5 stitches.
Repeat*(1DC*5,2DC)
84 Stitches.
If you wish to larger size placemat, then follow the below mentioned increase pattern:-
Start each round with Chain 2(Not counted as a stitch)
Round 8--DC 6, 2DC in next stitch(96)
Round 9--DC 7, 2DC in next stitch(108)
Round 10--DC 8, 2DC in next stitch(120)
.....and so on.
Step 9:
Round 8:-
Chain 2.
1 Double Crochet Cluster in the 1st Stitch.
Chain 1.
Skip 1.
Repeat(1DC Cluster,Ch1,Sk1).
Slip Stitch on top of the first Double Crochet Cluster.
To Make a Double Crochet Cluster Stitch:-
- Yarn over, insert the hook into the stitch, yarn over and pull through 2 loops on the hook.(This is same as doing a Double Crochet Stitch. It is just that , you don't finish the Double Crochet Stitch and continue doing the first part of the Double Crochet Stitch again and again).You should have 2 loops on the hook.
- Yarn over, insert the hook in the same stitch, yarn over and pull through 2 loops. You should have 3 loops on the hook.
- Continue with the first part of Double Crochet stitch untill you have 4 loops on the hook.
- Yarn over and draw the yarn through all 4 loops on the hook.
- Chain 1.
Step 10:
Round 9:-
**This round, we will be working only in the Chain 1 Spaces.
Slip Stitch into the Chain 1 Space.
Chain 2.
7 Double Crochets in the Chain 1 Space.
Slip Stitch into the next Chain 1 Space.
Repeat(7DC,SL into the next Ch1 Space).
Slip Stitch on top of the 1st Double Crochet and weave off.
