Father's Day DIY: Embossed Leather Luggage Tag & Tie Clip
Intro: Father's Day DIY: Embossed Leather Luggage Tag & Tie Clip
A leather luggage tag is for people who have their travel act together. It also looksway better than paper tags. Our kit has everything you need to make an embossed leather luggage tag, and there are also materials to create a monogrammed leather tie clip. Makes a great birthday or Father’s Day gift.
The kit includes a letter- and number-punch set, two pieces of Tandy cowhide leather (for the tag and tie clip), 18-inch suede string, and two tie clips. Follow our DIY tutorial to find out how to create your luggage tag and tie clip.
STEP 1: What You'll Need:
Pencil
Paper
Low-tack painter’s tape
Wooden block or ruler
Hammer or mallet
Cutting board
X-ACTO knife
STEP 2:
Leather is more receptive to being stamped when it’s damp. Dip your leather pieces into a bowl of water. They don’t need to soak, just dampen them.
STEP 3:
Let the leather dry. It’s ready to use when it has almost returned to the color of dried leathe
STEP 4:
Try a few mock-up drawings before you start. You can use an X-ACTO knife to trim the shape of your luggage tag before you start.
STEP 5:
I found if difficult to eyeball the layout because it’s very easy for a few letters to be crooked and make the whole piece look wonky. So I used low-tack masking tape for my lines. (Tip: If you use a high-tack tape, it can tear at the fibers of the leather when you remove it. You can usually combat this by not pressing the tape down too hard, or use a bit of water on your finger to massage away the unwanted texture on the leather.)
Hold your ruler or wooden block on the tape line and put your letter punch up against the flat surface to ensure straight, properly lined-up lettering.
STEP 6:
It’s hammer time. Do your hammering on a steady surface. You don’t need to use that much force — one sharp tap, straight down on the top of the letter punch should suffice. If you didn’t apply enough pressure, you can carefully realign the stamp and do it again.
STEP 7:
Working on a proper cutting board will absorb a lot of the sound. (I cheated and used scissors to make a period on the tie clip.)
STEP 8:
Gently peel off your layout material. Smooth out unwanted textures (See tip from step three).
STEP 9:
Loop your leather cord through the hole to complete your luggage tag.
STEP 10:
Use an epoxy to glue your small leather-stamped piece to your tie clip. Let dry and wear!
4 Comments
smcmasters1 8 years ago
Xepol 9 years ago
Did you just post your home address and personal name on the internet?? You might want to change your pics.
tootyaa 10 years ago
hi ..i live in iran & have a leather shop & make hand made leather bag ..... i want to buy tools like your but it s not in iran . can you help me ? & send these for me ? i will pay price to you
its my blog ...please visit & left a comment ..... i wait you
786Ayesha 10 years ago
Nice!! Pineapple on your work table?ha ha
