Faux Silencer
Intro: Faux Silencer
how to make a fake silencer
STEP 1: Getting Materials and Tools
Gather these items:
- An Airsoft pistol of your choice
- Metal Conduit
- A Highlighter
- & two CD's
- Tissue
- A rotary Tool or a drill and preferably a press of some sort
- Super glue or a strong glue like it
- A 3/32" drill bit
- Needle Nose pliers
- A saw frame
- A saw blade (for cutting metal jewelry blades work like charms)
STEP 2: Preping the Highlighter
- Get your highlighter.
- Remove the back of it .
- Take out the ink cartridge.
- Flip your pen around remove cap the proceed to pull out the felt tip .
- Then cut of a piece of the nozzle 3/8" is left.
- Then with you drill or rotary tool drill six columns of holes around the case of the highlighter.
STEP 3: Getting Your Conduit
- First measure the straight section of your highlighter.
- Then grab your uncut section of conduit and mark on it how long it needs to be.
- Get your saw and frame and proceed to cut off your conduit piece
STEP 4: Cutting Your End Caps
- gGet your CD's .
- Measure your conduit onto the center of your CD's and mark with a writing implement.
- Drill a hole on the edge of your line.
- Then proceed to cut with your saw.
STEP 5: Assembleing and Finishing
- Get all your parts and your super glue.
- Get your highlighter case and wrap your tissue paper around it so it is as flat as possible.
- Then slide into your conduit twisting as you go.
- Then glue on your end caps and depending on how clean your cuts were you may need to sand the edges of your end caps but i didn't so you might not have to.
- Get your paint of any choice probably black and get it to match your guns finish.
- your done
23 Comments
Deltaforce2555 15 years ago
Pbyrd 15 years ago
llamatard 12 years ago
Pbyrd 15 years ago
I wouldn't make these anymore because of that reason. But still a good instructable. I just wanted to let you know that these are real so you wouldn't get into trouble making these.
nightcreep20 15 years ago
daelans 14 years ago
AnarchistAsian 15 years ago
zombiekiller42 13 years ago
cyprian916 13 years ago
sharlston 14 years ago
chicks dig me 15 years ago
Matt21497 15 years ago
TyIslander 15 years ago
footer0 15 years ago
