Featherboard Evolution
Intro: Featherboard Evolution
The problem with featherboards is they aren't feathery enough. Meet the bristleboard.
We are redecorating and it's up to me to produce miles of trim. I bought a load of nice 1 x 4s, but I really needed 1 x 2s and ½ x 2s. There was a lot of ripping to be done, and I wanted it to go well. This jig was a big help, so let's go.
You will need a scrub brush, some scrap plywood, a pair of screws, a utility knob, and a functional workshop.
STEP 1: The Business End
Take an old bristle brush or pick up a new one, and cut into nice chunks. I used a hacksaw with the bristles held loosely in a vice, and this step was over before I could capture an action shot.
STEP 2: Make the Board Parts
You know all those bits of scrap plywood you've been saving because you knew they would be useful someday? Their day has arrived!
Cut a strip to compression fit into your saw slot and wider one that will span the distance to the blade. It would be good to make that width have something to do with the width of your brush piece. But don't waste any time measuring.
Then cut a slot to slip the bolt on your knob. Center-ish and parallel-ish is good. I used a router and did a really bad job. It didn't matter.
STEP 3: Connect the Pieces
Screw the back of the brush to the end of the board. Of course you'll want to drill and pilot the holes. Or not.
Once again, center-ish and parallel-ish is good.
STEP 4: Thread and Go
Since my knob had a threaded stub on it, I simply drilled an undersized hole somewhere near the center of the slot board and spun the threads into it. I tried to think of a reason to make this more complicated, but I gave up.
If you find featherboards tedious to make and annoying to use, you'll love the bristleboard. The bristles provide more consistent pressure over a wider range of flex, so this is much quicker to set up and works far better. Plus it's so freaking ugly, you have to give it a home.
Cheers from Sarasota.
33 Comments
jmhjr 9 years ago
Nordstern1955 10 years ago
Prima! Super!
drobertson123 11 years ago
Great quick and easy featherboard setup. I could actually see this as a down facing featherboard setup also, in addition to the fence facing setup you have. It looks much more tolerant of bad setups and softer on the wood.
I am also guessing that this is a bit easier on softwoods. I have had my traditional feather board leave marks when I am working with soft wood.
Just a quick question on the adjustment slot with the screw down knob. It looks like you are already right up to the blade with it slid all the way back. Is there a reason for that? Do you have two miter slots on the tablesaw? I am mostly just curious to see if I am missing something.
And greetings from Port Saint Lucie, over on the other side.
Doug
flavrt 11 years ago
You are very observant. Yes to everything. The bristleboard is more tolerant of sloppy setup. I will definitely use the 2nd half of my brush vertically as a hold down.
There is very little travel remaining at the right end of the adjustment slot, which is what I needed for one large project at the saw and router table. I did such a bad job of cutting this slot, it should be done over from scratch. But I've grown accustomed to its ugliness. ((The key theme of my Instructables is skipping by details that don't matter.))
I mostly like this for the concept of using the brush as a featherboard. I sometimes do some work on very thin and delicate materials using a micro table saw (modified dremel). I am curious if I could use the same idea with a natural bristle brush and completely cover the cutting area. I don't really care if I lose a few bristles and the even downward pressure at the point the blade is cutting could be very handy keeping the cut clean and smooth. Hopefully it would help reduce vibration on thin materials.
Overall, thank you very much. You got me thinking. Now I need to do some experimenting.
flavrt 11 years ago
Please let us know how things develop.
Bill WW 11 years ago
To copy a from another comment, "I've been on the receiving end a MANY kickbacks," and at leart one left it's imprint on my gut!
I once made what I called a "feather bar" out of strips of countertop laminate. It's only claim to fame is that it is long, and can be used for panels and ripping long boards.
See attached photos.
flavrt 11 years ago
Fantastic. An expression of Modernist elegance in a practical device.
We are all developing useful ways to exploit the superior elasticity of artificial materials. However, nothing I've seen can compete with my bristleboard's ugliness.
Jah3-Maniac 11 years ago
I use metal bristle brushes, and a double slotted board, and believe me this provides total anti-kickback protection as well as holding the board in place perfectly. And no the bristles do not scratch the board noticeably.
I will make some of these for use as hold-downs and hold-ins for my router table.
Thanks
flavrt 11 years ago
I think metal bristles present different characteristics that are worth exploring. It would be great to upload an image of your jigs so everyone could view those alternatives.
The hold-downs use scrap bearing-studs from a commercial print house.
See photo -
flavrt 11 years ago
Or is this another weird artifact from using the Apple browser?
I just have no idea how to let you see it!!
I assumed that it was going to be visible when I uploaded it - hence the "see photo below" - ah well.
flavrt 11 years ago
The roller bearings are really very good at adding pressure without adding commensurate friction.
BTW - Note the little crank at the bottom right - that's for my homebrew router lift, of which I am very pleased/proud!
flavrt 11 years ago
Thank you so much for following through.
MITER-SLOT FEATHERBOARD - http://www.woodcentral.com/shots/shot32.shtml
One of these days I will start doing 'ibles myself - I have LEARNED SO MUCH from Instructables that I feel I MUST give back!
BTW that is not an idle promise/comment - I have very little free time at present since what I am doing is actually tooling up to finish the cabinetry in my new/old house that I am presently refurbishing. Lots of the jigs and fixtures I am using had their start right here on this site - of course 40 years experience making jigs and fixtures allows me to make radical changes where I see the need.
I have been doing carpentry/woodworking for years BUT cabinetmaking is new to me. in fact the first fixture in the house is a staircase we finished on friday.
So Flavrt, please carry the torch a bit further, but i will surely join you later.
ejensen99999 11 years ago
flavrt 11 years ago
A couple of things need to said about this issue. We can't publish a full safety course within every Instructable. Comment trolls always take advantage of this. They scream about safety as a way to get attention without actually putting some effort into creating a presentation that is interesting and informative. All the venom and fallacies and mischaracterizations and ad hominem and hysterics tell us more about them than the subject at hand.
OTOH, comments are great for adding depth and breath to Instructables. I always learn something, and that's why I put some effort into encouraging a healthy discussion. Unfortunately I've seen many conversations on woodworking turn nasty. I believe this is due to the reclusive nature of the craft. Often woodworkers with decades of experience don't perceive the narrow breadth of their experience. So when new things come along, they see no benefits and react with anger, fear, and confusion. I think we should tolerate this behavior because our methods must be robust enough to defend against even the most buffoonish criticism.
Which is not to say that I take the danger of kickbacks lightly. I've toured a furniture factory where the operator of a straight line track saw had to wear a chainmail apron. That saw kept making spears and shooting them back at him all day. However, I don't believe old-fashioned featherboards provide good protection from this hazard. They are simply not springy enough to be reliable. If the featherboard is bumped or shifts or is initially set up a few thou too loose, there is only an illusion of protection from kickbacks. And that's worse than nothing at all. Bristles are not as strong as wooden fingers, but there are many more of them and each is far more position tolerant.
The best safety advice we can give to newbs, if we are so obliged, is all safety devices fail. Fingers and eyes and other essential body parts need to be out of the flight path when they do.
