Feel Like a Sir Ninja
Intro: Feel Like a Sir Ninja
**If there are spelling errors, I'm sorry! I'm not totally fluent in English so I'm using a translation tool as an aid for making this Instructable.**
I always imagined myself as an old man and how would i protect myself. So I thought, why not a bengal with a blade?
This Instructable is the step by step how I did it.
STEP 1: Materials / Tools
So, the materials i used here,i have all at my home and the wood, I used construction wood.
Materials:
-Blade iron: 70cm
-Wood pieces:
- 80cm x 2cm x 4cm
- 10cm x 2cm x 4cm
- 15cm x 5cm x 4cm
- Wood glue.
- Varnish.
- Nail
Tools:
- Set-square
- Chisel
- Hacksaw
- Pencil and rubber
- Sandpaper
- Drill-(1" and 1/3 ")
- Planer-manual
- Soldering iron
- Hammer (Rubber and Iron)
- Brush
- Metric trena
- Screwdriver
- Whetstone
- Staples-wood
- Goggles
- Morça
- Circular saw
- Drilling machine
- Emery
- Hacksaw
Materials:
-Blade iron: 70cm
-Wood pieces:
- 80cm x 2cm x 4cm
- 10cm x 2cm x 4cm
- 15cm x 5cm x 4cm
- Wood glue.
- Varnish.
- Nail
Tools:
- Set-square
- Chisel
- Hacksaw
- Pencil and rubber
- Sandpaper
- Planer-manual
- Soldering iron
- Brush
- Metric trena
- Screwdriver
- Whetstone
- Staples-wood
- Goggles
- Morça
- Circular saw
- Drilling machine
- Emery
- Hacksaw
STEP 2: Preparation Hood
I chalked the ends to get the alignment parts after.
I chalked with a pencil on the inner part where the blade will be from at 10cm base, so that the blade was not until the end. I scored the risk with the big chisel and with the chisel slightly larger than the blade i cut the part that she'll stay.
After doing this in two parts and sanded I glued with the wood glue. I held the two parts with the help of clips and let dry for a night.
STEP 3: After a Night
After the glue has dried, I scored the measures to cut the base of the walking stick, after ... I removed the excess with Planer-manual and sanded.
STEP 4: Preparing the Blade
I marked the right size and cut of the blade, nailing it to the handle of the walking stick, 8 cm long, with Durepoxi (A type of sugru).
STEP 5: The Handle
Using a piece of wood 10cm x 2cm x 4cm, I stuck and molded and I glued it on the cable using Durepoxi.
STEP 6: The Union
After sharpening the blade, I made the piece that holds the cable to the base of the walking stick using the same method as the other pieces.
STEP 7: The Gran Finale
I drew in the piece using a pencil and then carve using a soldering iron to burn the wood. After the ready drawings I passed varnish.
I used the iron rings to keep the base together.
25 Comments
Jake_Makes 9 years ago
Awsome!
Green X 10 years ago
cool cane. I want now.
JohnnyD77 11 years ago
DvsNegrito 11 years ago
mdlmusic 11 years ago
filpcl 11 years ago
arawn 11 years ago
filpcl 11 years ago
matokage 11 years ago
Alias eu já fiz uma espada com o mesmo material, se não me engano era uma suspenção de fusca.
Parabens por ter seu Ible' na primeira pagina!
filpcl 11 years ago
The Rambler 11 years ago
filpcl 11 years ago
gn0stik 11 years ago
bruce5000 11 years ago
filpcl 11 years ago
monsterlego 11 years ago
filpcl 11 years ago
l8nite 11 years ago
filpcl 11 years ago
The Metal One 11 years ago
