Felt Branch Garland
Intro: Felt Branch Garland
I wanted to make a garland that wasn't merely a bunch of leaves dangling from a string. I didn't see any felt branches out there, so I made my own. I opted not to make them stiff with wire; I wanted it to still have a soft feel to it.
I also wanted to make something festive and wintry without being obnoxiously red and green. I love the look of the dark, bare tree branches poking out of the snow in winter.
STEP 1:
Fold a piece of your branch colored felt in half. You can either cut long thin strips of felt before or after sewing. Either way, make sure your fabric has two layers and all branch segments are tapered at one end.
I found it easier to cut the longer strips ahead of time and sew them with a zigzag stitch, using the same color thread as my branch. Make sure to reverse stitch at either end of the branch segment so the thread doesn't loosen later on.
The smaller branches were easier to sew first and then cut. I sewed a rough line down the doubled fabric for each - I didn't want them to be perfectly straight or they wouldn't look as natural to me. I made some of them branch by sewing a connecting zigzag stitch heading off in a slightly different direction. I cut the small branch segments one at a time after each new line of stitches was sewn.
Once I had all the branch segments, I sewed the large pieces together, making sure to leave a little overhang so that the tapered end could branch away from the main strand. I wanted this to feel a little less 2D, so I opened up the fabric at the sides of the branch strips (since they were sewn down the middle), pressing them open so that my fingertips were pressing the seam, and sewed them together along that opened seam.
STEP 2: Sew the Leaves
I didn't use anything to trace patterns on the felt; this garland was supposed to be slightly modern, so I just cut and sewed freehand.
Whether you cut the main leaf shape before or after sewing, the rest of the process is the same. Use a straight stitch for this.
Sew a pointed oval (leaf) shape around the outside. Sew a straight line up the middle. Stitch back down along the middle line, then about 1/3 of the way down, sew a line out toward the edge. When you get to the edge, turn the fabric around and sew back toward the center along the line you just sewed, then make another line on the other side of the center vein. Turn around when you come to the outer edge, return to the center vein, then sew along the vein a little lower. Make two other branching veins just like the previous ones. Repeat this one more time. End the stitch at the bottom of the center vein, backstitching to make sure the thread stays secure.
I used two layers of felt for the gray leaves, and one layer for the white leaves. I wanted them to have a lighter, more ethereal quality.
I used black thread for the gray leaves and gray/silver thread for the white. I had the silver thread on the top of my sewing machine, and gray thread on the smaller bobbin underneath the sewing foot.
STEP 3: Put It Together
Sew the smaller branch segments onto the main branch with a zigzag stitch using whatever pattern you like.
Distribute the leaves evenly over the garland, using a straight stitch to attach them. You can either sew them along the middle vein using a similar thread color, or sew them along the base, using a thread that matches the leaf. Be sure to reverse stitch several times, securing the leaf to the branch.
I think this is the most rewarding part. The branches and leaves might take a fair amount of work, but I love to watch the whole thing finally come together.
Thanks for reading!
Thanks for reading!
5 Comments
afcron 11 years ago
jadkins7 12 years ago
porcupinemamma 12 years ago
jessyratfink 12 years ago
Penolopy Bulnick 12 years ago
