Introduction: Felted Soaps
This is a great way to preserve your soaps. also it’s a built in wash cloth! Great handcrafted gifts too! Also great for the whole family to do!
Step 1: Supplies
Get supplies together. What you will need is a boot mat. Can get at Walmart for $4. Nylon sock. Dish soap. Merino or corriedale roving. Bar of soap. 2 bowls, one for hot water and other or cold water.
Step 2: Wrap the Soap
Wrap the bar both horizontal and vertical
Step 3: Wrapping the Soap in a Sock
I found the best way to wet felt soaps is to prep it before adding it to the sock. This helps prevent the wool from moving and corners not covered. I put some dish soap on my hand, grab the bar of soap get it wet in hot water. I squish the wet wool around the bar. Make sure the soap is not exposed. Then add to the nylon sock.
Step 4: Felting
Scrub the soap on the boot mat for 5- 10 mins. Alternating from hot and cold water. You will know when you soap is done when it sticks to the sock, and you can pull with out it coming off.
Step 5: Finished Bar
When you take the soap out, press it in a dry towel. Let sit over night. Also you can join my Facebook group for felting soaps, Fiber Artist Felted Soaps
Fiber Arts Contest 2017
13 Discussions
3 years ago
Doesn't this shrink the inside soap a bit? Is there a minimum size soap to do this?
Reply 2 years ago
No it doesn’t. Also felted soaps last longer
Reply 3 years ago
With using dish soap it doesn’t shrink. The bar of soap is hard enough to handle the felting. Over time it will shrink, the felt will a lil. Then you have a neat lil pouch to do other things with
Reply 3 years ago
makes a good little scrubber afterwards!
Reply 3 years ago
I do 4-6 oz soaps. And for kids about 2-3 oz. so that it fits in their lil hands better.
3 years ago
Nice design!
Reply 3 years ago
Thanks
Reply 3 years ago
Thank you
3 years ago
That looks pretty, I haven't seen this done with soap before :)
Reply 3 years ago
Give it a try! It make the soap last longer and slightly exfoliating
Reply 3 years ago
It's a great way to make your soap last longer. You can also needle felt the soaps too
3 years ago
Nice idea!
Reply 3 years ago
Thansk
