Introduction: Fence in a Bag Set Up
About: My invention that is entering into retail
Follow these easy steps to get your fence set up fast.
If pole does not extend easily just twist one part of the pole while extending it.
Step 1: Fabric
Take out fabric and lay it out flat.
Step 2: Upper Hook
Insert top hook into the upper grommet of the fabric
Step 3: Unlock Pole
Turn black dial to the right to unlock the pole and pull to extend the length.
Step 4: Lower Hook
Insert bottom hook into the lower grommet.
Step 5: Lock Pole
Extend pole till the fabric is tight and then turn dial to the left till it is tight. This will lock the pole into place.
Step 6: Add Poles
After you have the first pole inserted, count the grommets along the top to number 10. Each grommet is one foot apart, so 10 will be 10 feet, there will be 9 empty grommets between the 2 poles. Insert your second pole the same as the first one and repeat above steps for the next 3 poles.
