Fillament Spool Roller/holder
Introduction: Fillament Spool Roller/holder
A thing, to put a couple of fillament spools. Those roll very nicely while draged by printer. Useful for multi-material printing systems.
3D printed parts (stl files attached).
2x Bearrings (5x22x12) or v-slot wheels (used in many 3d printer kits) per single roller
2x 10mm stell rods. Length does not matter much 500m rods are good enough to hold 6 spools.
6x M5 Bolts (30mm)
6x M5 Nut
Step 1: Step 1: Printable Parts
Get the parts printed. all should be printed on a side. Add supports for rollers (the onse that hold bearrings or wheels inside).
Step 2: Step 2: Assemble
Get everything assembled. This should be pretty straightforward.
In case printed pins are too tight - work them with sanding paper a bit. Then just hammer them into the holes. Don't forget to add the wheel or bearring.
Do not overtighten the parts holding the steel rods, as you might accidentally break them.
Be the First to Share
    • CNC and 3D Printing Contest
    • Rice & Grains Challenge
    • Puzzles Challenge
      Puzzles Challenge
    2 Comments
    Elaina M
    Elaina M
    2 years ago
    Neat - did you design it ? Thanks for sharing
    gradeckas.paulius
    gradeckas.paulius
    Reply 2 years ago
    I did design this one, but his is not something new - there are lots of similar designs available on the web. I did my version with the thought to use the parts I already have availalbe at home ;)
