Simple Water Filtration (Clean Your Own Dirty Water)
Intro: Simple Water Filtration (Clean Your Own Dirty Water)
In this practical, you will attempt to treat your own dirty water, make qualitative observations of the results at various stages and then suggest improvements. Read the practical, and identify the separation and purification techniques used.
Please Rate and Leave Comments.
Thank-you!!!
Thank-you!!!
STEP 1: Aim and Materials
Aim: To separate mud from water using filtration, but also purify the water afterwards.
Materials:
Dried Dirt (from the ground)
Bleach
x2 See Through Glasses
Water From The Tap
Spoon
x2 Filter paper
Funnel
Materials:
Bleach
Water From The Tap
Spoon
x2 Filter paper
Funnel
STEP 2: Method (Part1)
(1) Mix the dirt and water into one of the clear glasses. Mix until water is brown.
(2) Fold the filter paper in half, and then in half again. You should end up with a cone shape. Place inside the funnel.
(3) Put the other glass onto a flat surface and hold the funnel over it. Fill the cone filter paper(inside the funnel) halfway full of dirty water.
(4) Watch it drip through the filter paper and funnel. Your other glass should be filling up with clean water.
STEP 3: Meathod (Part2)
(5) Once that has finished filtering, repeat steps 3 & 4, but using the other piece of filter paper. Wrince out the leftover dirty water and switch it with the glass full of dirty water, so that the glass of filtrated water is in your hand, and the other is underneath the funnel.
(6) Re-pour the filtrated water into the funnel and watch it drip into the clean glass.
(7) When done, add 2 drops of bleach (which contains chlorine) to your filtrated water. Stir for 1 minute.
STEP 4: Analysis
When we poured the dirty water into the filter paper, the dirt didn't go through the filter, but the water did. This is because of the tiny holes in the filter paper.
Extra Research:
Research the main arguments for and against the fluoridation of a town's water supply.
Extra Research:
18 Comments
robot 1234 7 years ago
That is useful science for helpping people in africa.
sana rizwan 8 years ago
no i meant yes as in yeeeeees
i don't know if its safe to drink
yes i am doing a project on this and this is perfect
ThinkD 9 years ago
is it safe to drink if so why
thermoelectric 14 years ago
You're instructable would be a lot better and interesting if it had photos, it's just pretty boring just having to read everything. And you might have made the instructable but not followed it.
Hydroelectric 14 years ago
RulaA 9 years ago
yeah
RulaA 9 years ago
man you are scientific and clever thanks dude
EmilyL3 9 years ago
kkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkk
EmilyL3 9 years ago
This was vary helpful for homework
sgt_rock 12 years ago
spark master 12 years ago
http://rvbasics.com/techtips/sanitizing-your-rv-fresh-water-system.html
from another site
http://www.i4at.org/surv/bleach.htm
Whether you use Clorox Bleach in an emergency or for everyday chores, it's always an environmentally sound choice. After its work is done, Clorox Bleach breaks down to little more than salt and water, which is good news anytime.
*Ratio of Clorox Bleach to Water for Purification
2 drops of Regular Clorox Bleach per quart of water
8 drops of Regular Clorox Bleach per gallon of water
1/2 teaspoon Regular Clorox Bleach per five gallons of water
If water is cloudy, double the recommended dosages of Clorox Bleach.
(Only use Regular Clorox Bleach (not Fresh Scent or Lemon Fresh). To insure that Clorox Bleach is at its full strength, replace your storage bottle every three months.)
**(Clorox Bleach Sanitizing Solution)
Mix 1 tablespoon Regular Clorox Bleach with one gallon of water. Always wash and rinse items first, then let each item soak in Clorox Bleach Sanitizing Solution for 2 minutes. Drain and air dry.
The Ideanator 14 years ago
skylane 14 years ago
PUREX and CLOROX bleach used to have water purification directions on the (glass) bottles... years ago. It was just a couple/few drops per gallon. It would kill germs, bacteria, etc.
Bleach (sodium hypochlorite) is a very common, easy to find product and much safer than Hydrochloric Acit (HCl)
I have a hole in my sidewalk where a LITTLE BIT of diluted Muriatic acid spilled. I'd immediatly poured a baking soda solution on it to neutralize it.... Dangerous, corrosive stuff, it is...
I'm not necessarily recommending the bleach, but if it were an emergency situation, I'd do it in a heartbeat...
