Finding Electrolytes in Orange Juice and Sports Drinks
Intro: Finding Electrolytes in Orange Juice and Sports Drinks
I had to come up with a science fair project so I decided to play with food and find the stuff that you can generate electricity with, known as electrolytes. While playing with your food you will find out if orange juice has more electrolytes than a sports drink. This is a great project for older kids science projects. It is also is very informative for sports considering that electrolytes are very important to staying heathy and active.
STEP 1: Materials
You will need:
orange juice
a sport drink of you choice (preferably Gatorade)
Bare copper wire, 24 gauge
wire cutters
ruler
1 in. plastic tube ( you can remove the insides from a pen and cut to one in.
9-v battery
9-v battery clip ( this is optional but it makes it a lot easier attach the wire to the battery.)
6 in. Wire with alligator clips on both ends (2)
small bowls ceramic, glass, plastic, NOT METAL (3)
masking tape
permanent marker
distilled water
tap water
digital multimeter
paper towel
alligator clip with out a wire attached
orange juice
wire cutters
ruler
9-v battery
masking tape
permanent marker
distilled water
tap water
digital multimeter
paper towel
STEP 2: Putting the Pieces Together
cut 2 6in. copper wire pieces
wrap 1 wire peice around the plastic pen tube close to the end of the tube and leave about 2 in. of copper wire unwrapped
do the same with the other wire on the opposite end of the tube.
the alligator clips with wire will come with clips on both ends but you will need to cut off one of the clips from the red wire and attach the loose wire to the positive end of your battery using the battery clip.
cut off one clip from the black alligator clips with wire
attach the clip to one of the copper wires that is wrapped around the tube.
attach the wire from the clips to the negative end of the battery with the battery clip
STEP 3: Attach It to the Multimeter
by now you will have a alligator that is attached to a red wire.
clip that to the positive wire of the multimeter.
with the negative wire from the multimeter attach it to the other copper wire that is on the tube using an alligator clip.
Now you are done creating your measuring tool. It should look like the one in the pictures.
STEP 4: Measuring the Electrolytes
set your multimeter to 200 microamps
pour the 4 drinks into separate bowls
put only the plastic tube and copper wires into the drinks one at a time ( orange juice, gatorade, distilled water, and tap water
read the number on the screen of your multimeter.
the drink that has the highest number on the screen after putting the tube in it has the most electrolytes.
You are done playing with your food! I have my results on the next slide if you are going to cheat and not do the experiment.
STEP 5: The Results
Orange juice: 24.6
Gatorade: 20.4
Distilled water: 0.1
Tap water: 3.1
The orange juice had the most electrolytes and can be healthier depending on what your your body needs. The results show that It would be healthiest to drink Orange juice before a sport game or work out then drink gatorade afterward.
Gatorade: 20.4
Tap water: 3.1
22 Comments
alettam030780 4 years ago
BunyereK 7 years ago
can you explain the use of tap and distilled water? make it really easy to understand
themoose64 7 years ago
peace_maymay 7 years ago
Hi, I'm doing this project now and I'm having a little bit of trouble with the small tube. In the images is the small blue tube the one from the pen? How did you take it out?
It's from the pen. You just take the parts form a cheap pen out and use the hollow plastic tube.
What is the diameter of the tube
It's not really important to the results of the experiment. So whatever the pen's diameter is will be the tube's diameter.
sadoroga 8 years ago
What does orange juice contain for it to have more electrolytes? And, what is the unit of measurement for your results?
themoose64 8 years ago
The multimeter can measure voltage, current, or resistance. The best unit of measurement to properly display the data in this experiment is Siemens.
PaulinaL3 8 years ago
I did this project! This is great, thank you so much themoose64! I had so much fun making it and you explained it so well. Just one question, is it mandatory to do the distilled water? Where did you get your multimeter?
Hpisthebomb 8 years ago
Why do I need to know the distiled water and tap water?
Thank you!!
opare_rocky 8 years ago
how do you measure the electrolytes please reply as soon as possible.
lnecaise 10 years ago
themoose64 10 years ago
wilgubeast 11 years ago
