Finger-Joint Box
Intro: Finger-Joint Box
Simply follow this tutorial to create your very own finger-joint box!
STEP 1: Step 1: Cut Out Sides for Box
Cut out four 250x100x12 mm pieces of wood for the sides of the box.
STEP 2: Step 2: Cut Out Lid Pieces
Cut out four 250x15x12 mm pieces of wood to make the lid for the box. Then cut the ends off at a 45° angle, as shown.
STEP 3: Step 3: Cut Grooves in Lid and Sides
For the lid,cut a 5 mm deep, 3 mm wide groove, 5 mm from the edge, as shown. Do three of the four sides.
For the sides of the box, cut a 5 mm deep, 6 mm wide groove, 7 mm from the edge, as shown. Do all four sides.
STEP 4: Step 4: Marking Out the Sides
Mark out the pieces for the box as shown.
STEP 5: Step 5: Marking Out for the Hinge
On the piece of lid that a groove was not cut in, 50 mm from the edges, trace around the hinge as shown.
Do the same on one of the sides of the box, making sure that the hinge would be facing outward, away from the grove in the box and on the top, the side that the groove isn't.
STEP 6: Step 6: Chiselling
Now chisel out inside the spot that was traced around the hinges. Chisel down about 2 mm, or the width of the hinge, as shown.
STEP 7: Step 7: Cutting Out the Finger-Joints
Now cut out the spots on the pieces of wood for the sides of the box that were previously marked out, as shown. Once the cutting out is complete, file the edges as necessary to fit the sides together.
STEP 8: Step 8: Cutting Out the Bottom and the Lid
To make the bottom of the box, cut out a 245 x 245 mm square, from a piece of 6 mm thick wood.
To make the lid, cut out a 245 x 245 mm square from a piece of perspex that is 3 mm thick.
STEP 9: Step 9: Gluing Together the Sides
Once the bottom of the box has been cut out and all the sides of the box can neatly fit together, you need to apply glue to the faces of the fingers that will be touching, and and fit all the pieces together, with the groove that was cut out at the bottom and on the inside of the box, and with the square of wood inside the grooves.
STEP 10: Step 10: Gluing Together the Lid
Now glue together all the pieces of wood for the lid. Make sure that each corner is at a 90° angle and the perspex fits neatly inside the grooves. The area chiseled out for the hinges must line up with the chiseled out area on the lid.
STEP 11: Step 11: Sanding and Puttying
Now it is time to sand the sides of the box and the lid if necessary. Make sure that all the finger-joints are flush, and the edges line up correctly. If there area any gaps between joints then they may be filled with putty. Once the putty has dried, lightly sand the box again.
STEP 12: Step 12: Applying a Finish
It is now time to apply a finish to the box. Varnish, oil or other kinds of finish can be used on the box.
After the selected finish has dried, the box is complete. The box can be lined with cloth or other materials if you want.
2 Comments
Martin Prins 5 years ago
DIY Hacks and How Tos 5 years ago
Great looking joint work.
