Firefly Lights Using Dollar Store Tea Lights
Intro: Firefly Lights Using Dollar Store Tea Lights
Here's a simple way to get those cool theme park fireflies in your haunt this year. They take about 10 minutes each to make and the effect is amazing. You will need:
Tea Lights from a dollar store
1 meter CAT5 cable (or other thin 24AWG wire)
Wire Strippers
Soldering Iron (Optional)
Lets get started!
STEP 1: Tea Light Anatomy Part 1
These dollar store tea lights are perfect for this instructable, but any LED tea light will do. They all have the same anatomy: a battery, battery door, switch, and a special flickering LED.
What you want to do first is take off the battery door and remove the battery. See that little wire sitting there? That is the cathode or negative lead of the LED.
STEP 2: Tea Light Anatomy Part 2
Once you have the cover off, let's look at the way the LED sits in its holder. The cathode lead goes down and is bent at a 90 degree angle in the battery compartment. The anode or positive lead of the LED is set inside the tea light above the switch. In the off position the anode lead does not touch the switch, but it will in the ON position. I know, stating the obvious, but we will need to replicate this arrangement with our wire a little while later.
Remove the LED remembering where the LED leads were located.
STEP 3: Getting the Wire Ready
Slice the end of your 1 meter cable to expose the wires.
Grab the cable outer insulation in one hand and the wires in the other hand and pull until the outer insulation is separated from the wires. Discard the insulation,
Strip about an inch of insulation from one pair of wires. Leave the wires twisted.
STEP 4: Cathode
STEP 5: Anode
OPTIONAL: I used a soldering iron to melt the plastic around the wire to secure it in place.
STEP 6: Feed the Wire Through and Put the Cover Back On
STEP 7: Connect the LED
OPTIONAL: I soldered the wires to the LEDs so they won't have connection problems on Halloween. I also put the plastic "flame" on the LED to soften the light a bit. The LEDs in my lights were directional so this helped the fireflies have a more uniform glow.
One final touch might be to paint the wire and enclosure black. In most situations it's not necessary.
STEP 8: How to Make Fireflies Dance
If the air is still, place a fan below the fireflies to get them moving. It doesn't take much air movement to make them dance.
Have fun and thanks for reading my first instructable!
2 Comments
ThisIsMyNameOK 9 years ago
Cool idea. I destroyed a couple of LED candles last year because I wanted to make some glowing ehes. But I just took the LED out and then taped it to the battery. Now I know another wat to do it. Thanks. :-)
MsSweetSatisfaction 9 years ago
Awesome hack! Welcome to instructables! Thanks for sharing!
