First Aid Kit Hack How to Make a Emerg Smoke Signal / Smoke Bomb
Intro: First Aid Kit Hack How to Make a Emerg Smoke Signal / Smoke Bomb
If you are ever in an emergency situation where you need to signal for help, look no further than you First Aid Kit.
This hack of a first aid kit will have you making an emergency smoke signal or smoke bomb.
STEP 1: Gather What You Will Need
1 instant cold pack from first aid kit
several sheets of news paper
String or twine
bucket
water
STEP 2: Prepare Instant Cold Pack and Prepare Ammonium Nitrate Solution
Carefully cut open an instant cold pack
take out water sack
pour ammonium nitrate crystals in a bucket
add water to ammonium nitrate while swishing the bucket
add just enough water till all the ammonium nitrate is dissolved
STEP 3: Adding the Newspaper
add sheets of paper to ammonium nitrate solution
keep adding sheet till all solution is absorbed by the newspaper
take newspaper out of the bucket and lay on flat surface to dry for a few hours.
Once dry tightly fold the newspaper into a roll and tie with string.
STEP 4: Get Ready to Be Rescued!
It is now ready to signal your rescue
just light one end on fine and stand back and wait for help to arrive.
“Be Prepared, Stay Safe and Survive.”
6 Comments
bdanderson 9 years ago
SurvivalCentral 9 years ago
tomatoskins 9 years ago
This is awesome! Thanks for sharing your knowledge!
emrude 8 years ago
How much smoke does one batch make? I want to smoke my travel trailer to find small leak and smoke sticks cost $20. I would of course put in firesafe container.
emrude 8 years ago
Wanted to say I made smoke bombs for my rv trailer. One pack made four one page bombs. They burn fast and completely. I used packs that had already been used. Added water to dried chemical and it worked fine. I used a small smoky joe grill to contain the bombs. I am stripping caulking and replacing seals, when I finish sealing the rv, I am going to repeat smoke test.
