Five Cent Hoop Earrings
Intro: Five Cent Hoop Earrings
Tools:
Sliding square
Razor blade
Center punch
Small hammer
Large hammer
Mandrel (I used a pry bar)
Rotary tool
File
Drill press
Sockets
80 Grit sand paper
400 Grit sand paper
2000 Grit sand paper
Polishing Compound
STEP 1: Mark the Center
Clamp the ring. Starting with a small drill bit, drill through the premarked center. Progressively drill a bigger hole until it will fit on the mandrel your using. I used a pry bar as the mandrel.
STEP 2: Start Hammering
As you hammer rotate the mandrel and apply slight pressure towards the anvil. This hammering and pressure helps elongate the coin as it moves down the mandrel. As the coin stretches, check it against the measurement you want.
In other words the bigger you want the ring, the more you have to hammer. View the pictures of how the hole gets bigger measured against my pinky.
STEP 3: Keep Hammering
As you hammer the ring will expand. I find it easier to use increasingly bigger socket bits to serve as an anvil. From my pry bar I went to a 12mm socket and ended up at a 7/8 socket.
Every so often hammer the edge of the ring as shown. This helps keep thickness to the ring as opposed to becoming a ribbon.
STEP 4: Mount the Ring
After you press the ring on the socket (or brass fitting), use a nut and bolt and secure it through the female end. The protruding end of the bolt will be used for mounting in the drill press. Mount the assembly in the drill press and spin it round. Use a 80 grit to shape it. You will shape the bottom side first.
Now you have to start being careful not to mar the ring. Use a piece of wood to tap the ring on and off the mount.
With the assembly spinning in the drill press, use progressively finner sand paper to make the ring it's final shape. I start with 80 grit, then 400, then 2000. Spray the 400 and 2000 grit sand paper with water. This prevents the sand paper from getting clogged with metal particles. Again, this gets HOT! And don't breathe the metal dust.
Flip the ring as needed. Use polishing compound to buff it to a shine.
STEP 5: Cut It in Half
Score a line with a razor blade. Minimal pressure is needed to mark a line. Once the line is marked, remove the assembly from the drill press and move it to a scroll saw.
Slowly and carefully cut the hoop in half with the saw at it's lowest speed setting.
Use caution and work within your experience.
STEP 6: Micro Hammer
Remove the tip of the engraver and flip it around to the flat side. Turn it on it's highest setting and use your new micro hammer to remove burs.
Finally, repolish the hoops in your drill press.
STEP 7: Link the Backings
Get a pair of earring backings from your local craft store and link them to your hoops.
You could also cut a section of earring out and solder a backing on.
25 Comments
rhaubejoi 12 years ago
I do want to say to anyone who is not aware. A *lot* of women have nickel allergies and if you make something for your love and she can't wear it, don't think your efforts weren't appreciated. I am severely allergic to nickel and cannot wear it at all. It eats my skin up as if I had spilled acid on it where it comes into contact. It used to just give me infections on my ear lobes, but has gotten much worse over the years.
HeWantsRevenge 9 years ago
could you coat said materials with nail polish or similar clear coat?
KiranP2 8 years ago
You should never use nail polish as a clear sealant. It has a strong smell that is irritating to some people, and it yellows with age. You could probably use Mod Podge or a similar craft-quality sealant, but you're probably better off using a product meant to be used on metal.
foxli 12 years ago
Mrballeng 12 years ago
spiderham 13 years ago
Mrballeng 13 years ago
HEY YOU 13 years ago
My grandparents were amateur jewelers and used a "ring sizer" to get a ring to a particular size - it is basically a narrow steel cone that you place the ring on and smack it with a wooden mallet to size it and get it back into round if it is bent. I have no affiliation with this site, but they have a ring sizer for $3.50 - http://www.gossamerwingsdesigns.com/bracelet-sizer.htm..
If you used pieces of pipe increasing in size, you could shape a ring by hammering down rather than around.
To buff your ring, you could use a sanding drum mandrel like these from Lee Valley http://www.leevalley.com/en/wood/page.aspx?p=42503&cat=1,42500,42501 but you can do the same thing with a small piece of rubber air hose, a bolt, a washer and two nuts (one to squeeze the hoe against the ring blank, and one to lock it in place)
Again, Very Nice work and good Luck
susanrm 13 years ago
sanewby 13 years ago
PeachyPete 13 years ago
I use the coin as is. You could anneal it if you want but I think it turns out fine for what it's used for.
Really, I've never tried anything other then just strait hammering but I'll give it a try and see how it goes.
I'm working on a two coin pendant. I'm hoping to have it posted before Valentines Day.
padawanspider 13 years ago
I know that Titanium is a very hard metal, yet is very, very slow to work-harden; this may also be true about the nickel coin alloy, since nickel is also a very hard metal. (Only a guess - I realize nickel and titanium probably have little in common other than both being corrosion-resistant).
Re-design 13 years ago
Nice instructions.
Nice idea.
Great photos. (It's nice to see someone how knows what focus is!)
spark master 13 years ago
mgauvin8810 13 years ago
rimar2000 13 years ago
hasha2000 13 years ago
